I only mix up a gallon at a time and add Stabil just in case, even though a gallon will seldom stay around for more than 12 months. Someone way back told me to use premium vice regular. It costs more, but I'm positive it makes my saws, leaf blower, hedge trimmer and weed whacker start a whole lot easier.
I use a product called Stabil or something like it, every time I make a new gas-oil mix, add Stabil to it and keeps the mix good for a long time. I use it for the last 15 years or so and ever had to dispose of any gas.
A friend went away for 5 years, when she came back, her car started at the first try.
No more than a gallon at a time. Use Stabil always and in everything. I now use only the blue Stabil instead of the red as the blue is made to over come the destructive effects of the ethenol now added to gas everywhere.
Even better is buying ethanol free gas. We have a couple of stations around that sell it...mostly to boaters and to people for their small engines such as saws. My Stihl dealer said ethanol has been great for his engine rebuilding business!
I would agree with Carol - use ethanol free gas. Today's small engines have a lot of plastic parts that ethanol gas just loves to gum up. If the gas is going to be stored for a period of time add stabil to it just to be on the safe side.
Ethanol free gas or aviation fuel if you can get it. Otherwise, 93 octane does seem to work better than regular. If the gas station has one of those pumps with only one hose and you select the grade, put the first 2 gallons in your car and the last one in the fuel container. The hose will contain a gallon or two of what ever the last customer pumped, probably the cheep stuff.
Slightly OT, but learn how to tune the saw and tune it to run on the rich side. Most come tuned too lean due to EPA regs and is a major cause of failures. You may need to remove the limiter caps from the needle valves. Also, opening up the muffler for butter exhaust flow (and retuning) can significantly improve power. There's a lot of information available on the various arborist forums.
John: Years ago a petroleum engineer told us that the 97 octane gasoline was produced with "dirty technology " and I have been using premium gasoline in my outdoor equipment ever since. Only lately have I been using ethanol free premium gasoline, and now that I use my chainsaw less and less, I put a little Stabil in the storage can when I fill it. Not in fifteen years of using premium gasoline have I had any problems with "Gum-up". My advise: Spend the extra $.50.
Get your self into a system never add gas or oil to a half full can as you can loose track of putting the oil in
I ALWAYS !!!! put in oil first then the gas
If I only have a litre or so left and are going out for a days cutting Ill often tip out the gas left and start again . A good Idea is once you have added oil to the can put a electrician tie on the handle or date the can with a felt tip
Use an oil that is colored
I learnt the hard way that I needed to get into a habit as my 880 had to have a birthday present of piston rings and head
I used to be in the service station business
and It was a known thing that gas should be turfed after a year or more as it can jelly fie
This breakdown can be accelerated if stored in extreme conditions.Also any gas left in the carburetter or saw tank can go to mush.I always tip this out after each use and run to the saw stops if I think I wont be using the saw for a while.
My Local Styl man says he only has 2 stroke mixed then he never has to worry things smoke a bit but no harm comes to 4 strokes
Read the manufacturer's recommendation for your saw. Typically, high test fuel is not recommended. I use Stihl 2-cycle oil and it contains a stabilizer so that Stabil is not required. If you acquired a used saw without a manual, I suggest you call your Husky dealer. Here in California, and if it is a relatively new model saw, I would ask your dealer to "fix" the EPA jets, so that the saw will run optimally.
Wow Dick I would be broke in a hurry using that. I use Premium fuel in all my saws (Stihl) as it was recommended by our Stihl Rep who is in my club. Just 20 cents extra a gallon and they all run great.
