Bar Top Rail Corner
Bar Top Rail Corner
Bar Top Rail Corner
Thomas Norton
I have been asked to make the following corner in hickory
http://www.bairdbrothers.com/Poplar-Bar-Rail-Outside-Corner-B005OSC-P4047C994.aspx
It has been awhile since I have done any turning but I feel I could do it. My thought is to make up 4 segment,pie shape90 degrees, and screw them to a plywood disc and mount the disc to a face plate and turn it.
Advice??
Thanks
Re: Bar Top Rail Corner
Sounds like you have it figured out!
Doug Trembath
Did That
Once.
You're on the right track.
I, however, did a full circle (for a smooth cut), used 16 wedges to maximize the face grain on the outside, and cut those pieces sequentially from the same board so the grain was consistent (pretty much ;) ). I then cut the 90� corner out of the donut. I used epoxy on the wedge joints, but pva and newsprint to glue them to the plywood "base".
You will also need a profile replicator to match the straight rails.
Re: Did That
Thomas Norton
My thought would be to make it in 4 sections and attach them to a plywood disc with screws. But leave 1 section not glued to the others in order to remove it to "check" the profile at different times during the turning process.
Comments?
Michael Mocho
Hi Thomas,
This is how I have made corner moldings to match a straight run of a particular profile:
Even if you only need two, make up the blank with all 4 segments so you are turning the full circle.
Mount the plywood- the stiffer the better- onto your largest diameter metal faceplate, and screw the segments onto it making sure they won�t protrude into the final turned surface.
I have found that turning a circular slot with a parting tool and using the inverted large cone on a Oneway live center will allow me to hold all the segments tight together without having to glue them. This way you can remove one to see how closely it matches the desired profile, and yet still screw it back onto the plywood faceplate to refine the cross section without having to mess with glue.
One trick I discovered is to trace the exact profile on the end of one segment, and then using a dremel, small router, or carving tools, cut away some of the end grain down to that profile line and re-attach it to the faceplate. This way you will be able to stop the lathe and see your progress as you near the pre-cut profile line. Just stop when the carved area is turned away.
Depending on the profile, you can often turn any inner profile of the group of quadrants and then remove the rest with the bandsaw after the turning is complete. A drum sander will clean up the rest of the inside radius.
Hope this helps.
-Michael Mocho
www.mmocho.com
Randy Gleckler
That's slick... I'll have to remember that
Thomas Norton
Michael Thanks!
Now I just have to come up with a cost!!
Michael-One more Question
Thomas Norton
Michael, Since I donot have the OneWay cone center do you think it would work to just screw the segments to the plywood disc and not glu the segments together?
Thanks,
Tom
Re: Michael-One more Question
Michael Mocho
Hi Tom,
It can still be done without the large cone center, but it depends on the thickness of the pieces. You could screw a smaller diameter disc of plywood on the top of the quadrants (into the waste area) and then press your live center onto that so you could still pull a segment to check the profile.
If the segments don�t need to be that thick, then perhaps screws alone will work, though I think there is an advantage to using the live center when you can- less vibration means a smoother cut = better surface = less sanding = more profit.
Good luck!
-Michael
Re: Did That
Thomas your on the right track. Glue up the 4 segments but put either a thin slice of the moulding or a cardboard copy of the molding in the joint when you glue it up. Now all you have to do is turn the wood down until you are flush with the molding piece.
The downside to this method is that you have to really accurate when you put it on the lathe. I thought the next time I do that I would glue up the segments but leave a gap or removeable piece in the glue up. Then once I got the piece roughed out I could replace the removeable section with an end cut from the moulding. This would make it easier to properly align the moulding so your final cuts are accurate.
I didn't read Micheals reply-same method
Comments
Actually, I don't care for the screw idea, a) because I hate hitting metal with a sharp tool :( and b) because with each piece pierced by 1, 2 or more screws, there's a better chance that one of the sections will split and fly off, possibly leading to a failure of the whole "deal." :O I may be woosing out here, but I'd much prefer the glue-mount for safety.
I also think you'll get better grain on the outside edges with more sections, at least on the "keeper" slice. I know, however, that more sections = more joints = more room for cut-angle errors.
I used a metal profile replicator to make a template from 1/16th plexi, then marked the high spots on the ring along with the very critical outside and inside radii. Get those outside and inside rings cut first so that you can verify that your corner piece will mate perfectly with the straight rail sections on either side. DAMHIKT
BTW I left the plywood backer unturned. It was marked with the layout lines, and then I used it to precisely cut the donut into 90� sections using the table saw fence. My corner came out deadnuts square that way, and I allowed for the blade kerf so that the "cord" of the corner points met the straight rails smoothly.
