Which Epoxy To Use
Which Epoxy To Use
Which Epoxy To Use
Stuart Johnson
I need to order some epoxy. My normal use is to fill bug holes and wind shakes in Mesquite. Some times I add black Rit dye but want to try using some other fillers. The stuff I had was okay but the brand name is totally gone from the bottles. I'm thinking about trying West System 105 with a slow hardener. Any other suggestions plus a good source for West or other brands.
Re: Which Epoxy To Use
Steven Antonucci
Try Michael's Craft Stores or A.C. Moores
steven antonucci
They have a small epoxy resin kit for casting stuff that is cheap (a few dollars). If you don't do a lot of it, it's a pretty good deal since you don't have to invest a ton of cash.
I got really lucky and had one of the 50% off coupons...
S
Barbara Gill
I love West System.
Stuart Johnson
Barbara, Do you know a good online source?
Barbara Gill
No I don't Stuart. I live in the middle of a big boating area so I buy it at the local auto and marine store in Urbanna.
Re: Which Epoxy To Use *LINK*
I use the West System. System 3 is also good and a little cheaper. You can get it at Woodcraft. You might look into some of the Inlace products. They have some cool stuff. I buy mine from here. www.turtlefeathers.net
http://www.turtlefeathers.net
Richard Allen
Richard Allen
The last epoxy I got was from pyacht.com
You need resin, hardener and the mini-pumps (or the small batch scales).
The pumps make it easy. The pumps meter out 0.8 oz for resin and hardener at a time. That gives you about 50 portions per quart of resin. Most of the time you don't need more than 0.2 oz so you are hunting down stuff to use the extra epoxy on or you are throwing away epoxy.
There are other high quality epoxies. I have used MAS epoxy and Evercoat epoxy and found them very good epoxy (though I am using West System epoxy right now).
If you buy the gallon size the cost per portion is reduced to less than 1/2 when purchased in the quart size.
As for filler the 407 is terrific it sands well and cuts well. If you want to color your epoxy in a bright light color like yellow the brown is going to be a problem. 404 is white filler that is great for color and is a fine consistency for good smooth filling but it is abrasive to sand and cut. 403 is white and easy to sand and cut but it is coarse so it doesn't provide a good consistent surface. So get 407 and 404. Use 407 most of the time and 404 when you want bright light color.
Performance Yacht Systems (West Systems)
Thanks Everyone
Stuart Johnson
It looks like pyacht.com has the best price. The small batch scale might be the way to go. I usually only use about 1/4 to 1/2 inch in a small bathroom type cup at a time.
