Question - Solar powered mini lathes
Craig Daymon
Several turners in our local group have mentioned seeing turners at local festivals using solar panels to power their mini lathes. If I remember correctly, they are variable speed lathes, though I don't remember why. They're talking about JET minis, not the tiny little pen lathes.
I've done some googling for information on "solar powered mini lathes", but turned up nothing of use. Does anyone know what is required or of any plans?
Thanks.
Re: Question - Solar powered mini lathes
Bill Howatt
I would think it is more likely they were using batteries and 12V DC motors and the solar was to provide some charging current to the batteries. Solar cells to dorectly power a lathe would be quite expensive and large.
The DC motors make it easy to provide variable speed.
Just a guess.
Bill
Brad Vietje
Brad Vietje
Craig,
I own a solar business, and have powered my mini this way. A lathe motor is an AC device, and solar panels produce DC power. Therefore, the solar panels charge deep-cycle batteries, and the stored power is then converted to AC power by an inverter. The solar panels do not power the lathe directly.
There's a lot of tech-y stuff to sizing this right, but basically, its an expensive way to power your lathe.
The inverter is sized to meet the demands of the motor (plus lights and other loads), the battery bank is sized for the length of time the power is needed, and the solar panel(s) are sized to replace the power used in a reasonable time. If you are setting up a lathe to turn for 3 - 4 hours at an event, the solar panel might be just for looks; you'd want enough power stored in the batteries to cover your need even if the skies were cloudy or raining. If you are setting up at a craft fair for a week, you'd want enough of a solar array to recharge the batteries, or you'd need to plug a charger into an ac outlet to do it.
If I recall, my 1/2 hp Nova Comet uses about 300 watts when running, but draws over twice that much to start the motor. For that size motor, you'd need a 600 watt or bigger inverter if pure sine wave, or a 1000 watt if modified square wave. A variable speed motor should only be run on a true sine wave inverter, to avoid running very hot and shortening the life of the motor or variable speed controller, and consuming a lot more power. Turning for 4 hours would be over 1200 watt-hours, plus lighting, or at minimum 1500 w-h or 1.5 kWh. That would be possible with two 6v deep-cycle batteries (about 220 amp-hours), but the batteries would last longer if you used 4 of them.
Let's say you use 350 watts x 4 hours = 1400 watt-hours. If there are roughly 6 hours of sunlight available to charge the batteries back up on a summer day (there could be more, but remember there are cloudy days, too), and the process is only about 80% efficient, you'd need roughly 300 watts of solar panels. Pretty soon, this can run into some real money.
The short answer is that to do it right, it is a pretty expensive way to go. If you have the opportunity to run an ac extension cord -- even if there's a small fee -- it will cost less to pay for power. If you want to use the mini at a summer cabin or while on vacation we should discuss off-list the equipment needed to do this right. While you may see people using a single group 27 or 31 marine battery and a small inverter to run the lathe for a few hours, and a little 50-watt solar panel to re-charge the battery, that's only enough solar input to replace about 1 hour of run time on most mini lathes on an average summer day, so the panel may be mostly for looks or to make a statement. Either you need 4-5 days to re-charge, or the solar panel will only be replacing about 1/4 of the power. You need more time or more watts of solar panels. You will also be beating the crap out of that battery, so it won't last very long.
Sorry for the long and technical answer. Running a small lathe on solar power is entirely feasible, but you may not want to haul the entire set-up to a craft show. Just having a few batteries that are charged up via solar panels before the event will be easier.
Safe spinning,
Brad Vietje
Newbury, VT
Brad Vietje
Brad Vietje
Right on, Bill. The power output from solar panels will vary tremendously with changes in the weather, so a dc-direct lathe would be pretty impractical, as it would speed up when the sun was bright, then slow when it was cloudy, and might not cooperate with your wishes at all. Power would be stored in batteries, and drawn off as needed. I've never seen a 12 or 24-volt DC lathe, so the only feasible way to do it would be with an ac-dc inverter that puts out 120 vac.
Safe spinning,
Brad Vietje
Newbury, VT
Brad Vietje
Yes -- But Not Fom Them *LINK*
Brad Vietje
Charlie is right, what is needed is an integrated system, not a bunch of parts. Real Goods has been in the solar biz a long time, but they are the most expensive source I know of. If anyone on the list wants to explore a solar power system, they should contact me off-list. That's what I do in the real world, and while we have lots of small cabin, camp, and cottage systems pre-sized for plug-and-play use, I didn't want to toot my commercial horn excessively here.
I'll be happy to help people size their solar systems (seems so funny to write that, since I design and install solar electric and hot water systems and I teach astronomy and telescope making), but please contact me directly for that.
Clear skies,
Brad Vietje, Newbury, VT
Owner, Green Works Solar Store, Groton, VT
Walt Bennett
Walt Bennett
Everyone's right on the solar/battery/inverter thing. I don't have the solar part, but have used a deep cycle battery and inverter to power a mini at craft and art festivals for years. Only problem I've run into is inverters don't like hot weather and will over temp. and alarm in 85 degree + ambient easily. Keeping them in the shade doesn't seem to help either.
Brad Vietje
Brad Vietje
Walt,
It will depend on the inverter. The lower-cost "modified sine wave" inverters will tend to run much hotter anyway, and the smaller ones may be getting hot if they're working hard to provide the power you are drawing. A pure sine or true sine wave inverter will use a lot less power and run cooler. The better units have a thermostatically-controlled fan to cool them. BTW: "modified sine wave" is a marketing gimmick. If you had a sine wave you sure as hell wouldn't modify it! That like modified gold aluminum -- not a chance.
There are two temp's that come into play -- the ambient temp, and the heat the inverter generates in making ac power. Any heat from the inverter is wasted power, so that should be kept to a minimum. Excess heat could mean the inverter is too small, or has a poor wave form, so it gets hot. It will also ruin the lathe motor, BTW. If you turn a lot in hot climates, you may need to use a different inverter. You can get a really rugged inverter or inverter/charger from Magnum that won't quit at any temp you can stand.
Clear skies,
Brad Vietje
Newbury, VT
Walt Bennett
Walt Bennett
I'm sure they are great, but the one I use has a thermostatically controlled fan too and doesn't cost more than my lathe. Since that's all I use the inverter for, I bring the inverter generator we use for our travel trailer when it's really hot.
Re: Yes -- But Not Fom Them
charlie belden
I pointed to Real Goods because they had a fairly decent tutorial on solar power and solar systems. Don't know if they still have the work sheets for determining your power needs for sizing a system or a description of the components that you need for a solar panel system any more. They were, and maybe still are
a good source for basic info.
There's a lot of things you must be aware of when working with a solar panel systems - one being that if sunlight is striking the solar panel - it IS "hot" - and can "bite" you - no On/Off switch on the panel's leads. If you don't know what you're doing you can get hurt - and/or destroy components.
