HOW TO TURN A SPIRAL TUBE
Keith Tompkins
keith tompkins
Here's how I did it. First I turned an hourglass shape, and hollowed it as far as I could, held in a chuck (A) Then, I turned a waste block, and cut a groove in it to hold the open end of the turning (B) Glued in place, I used a steady rest to finish hollowing. I then cut it in half, (C) and milled each cut dead flat. I then turned a smaller form (D) which fit the exact profile of turning A. Notice in the top view of (D) that I offset the inside in relation to the outside, to give varying wall thickness. I then cut the turning (D) into two sections, one section is glued to the top edge of form (A), and the other half is glued to the bottom edge of the other part of form (A). Then I turned form (E), a smaller version, offset the outside, and cut in half. Figure (F) shows the result of glueing pieces of (D plus E) together. Three turnings gave me enough pieces to complete the entire spiral tube form. Last step, cut away the opening in each half of the hourglass form, and fit the two original pieces back together. Once fitted, sand all pieces, and glue the two halves back together....a perfect grain match, since they were both one piece of wood.
Re: HOW TO TURN A SPIRAL TUBE
Don Orr
Oh sure-just like that. Now I get it. :\ :(
You make it look and sound so easy except I know it's really NOT.
Thanks for the description.
woodspinner
Keith
Thanks for the info.Some day I might try something like this.Very good explanation it's going to take some rereading to understand it better but still very good explaining.
Steven Antonucci
I was right!
steven antonucci
I figured it was the same process as the roses, but I wondered if you had cored the inner pieces to keep the grain match perfect.
Or if you had purchase a ROSE ENGINE lathe... ba dum bum!
Thank you, I'll be here all week...
Steve
Thanks Keith
Mike Foster
Great explanation. I thought it might be similar to your roses. I have turned tube forms using the same chucking techniques.
Don at Central Illinios
It looks fairly easy on paper, but I know it's not that easy in real life. How do you keep coming up with these wonderful turnings?
Keith Tompkins
keith tompkins
Hi Don, It's really not all that complicated to make one of these. The trick is to have the idea of a spiral in the first place, and then a basic plan of how to make it happen. Sometimes trial and error is involved, so I make several miniatures to get things right. My first spirals were much simpler, and I learned from making them. One idea always leads to another, and I keep a scrap book of all my ideas.... by now I have three full books, so I just pick the design that appeals to me the most.I literally won't have time to complete all the sketches I've made. Many turners look the other turners for inspiration, I look at simple things around me, or base my work on life experiences.
