It followed me home - now what to do with it??
~5.5" x ~12" x ~22" - solid cherry. Some end checks. Pretty much dry though - many years old.
So - I could make some end grain boxes - say maybe 4-6 at least - possibly 8.
I could make a couple of large bowls - but it is cherry and it is dry - therefore it would be a BIT hard to turn. My shoulders ache thinking about it. Of course if anyone has any ideas about how to make it easier to turn (other than with a bowl gouge). I could also do some end grain bowls.
Some really THICK rolling pins (just kidding).
Many ornaments (again - just kidding - smaller wood would be better).
So - if you had this chunk of cherry - what would you do with it?
Re: It followed me home - now what to do with it??
Steven Antonucci
I did... and I made a trencher
steven antonucci
No turning involved, but lots of carving and such.
A trencher is a long, squarish bowl that you can do 80% of the work with a tablesaw or a chainsaw...except that the last 20% is actually the 80%.
Steve
Re: I did... and I made a trencher
Don Wilcut
I would give it to Mike Stafford to make boxes.
Turn a LOT of toothpicks
Galen Vetterick
Terry Scott
Id turn it as it is a central bowl with long drooping wings
I'm sure Mike has enough wood
robo hippy
I wouldn't expect it to be hard to turn, as cherry really isn't that hard. You could get a couple of bowls from it if you core, and have some nice hollow form blanks left over, or blanks for cube turned on a bias type bowls. You could rip it on the bandsaw, and get some nice platter/bowl blanks. It would make really nice rolling pins, though I prefer the sugar maple for that as it is heavier.
robo hippy
Cube turned on a bias type bowls??
Please elaborate.
Re: Cube turned on a bias type bowls??
robo hippy
Start with a cube of wood. Mount between centers, very carefully marked. Turn the corners down to a 45 degree triangle about 1 inch per side. Now, remove, and turn between centers that are on these flat triangles. You end up with a bowl with 3 corners. If you hold the square between your fingers on two opposite corners and spin it, you can see what I mean. The top and bottom (corners between your fingers) will turn away, to tenons for chuck mounting, and the bottom 3 corners will disappear, leaving the other 3 corners for wings. Kind of an unnatural edge bowl.
http://www.youtube.com/watch?v=8oVw70_jAQY
This link shows it. The video is slow for my pace, and mounting between centers and turning off the corners is easier than marking and sawing them off. Really pretty cool. I have to see if I can do it and fit a lid to the top.
robo hippy
Thanks for the link.
I can do this with a chunk of the cherry and still have enough for many other things.
