Veritas - Innovation in Tools
Coring a "Dowel" Question.
I have a small log of soft maple that has ambrosia. The log is about seven inches in diameter. I turned an end grain bowl out of the base/stump. Turned it down to the point the ambrosia showed inside and out. Made the bottom about a 1/4" thick hoping it would not crack and it did not. But it did bulge, forming a little bump on the bottom. Need to cut the bump off as it causes the bowl to be tippy and rotate freely. I have enough thickness to do that, so I am pleased with the bowl. (Yes there is a matching dimple in the bottom of the bowl, but it is not objectionable.)
So, I want to make more of them. Has anyone tried putting a long blank on the lathe and coring it over and over to get repeated blanks? It seems that would create a number to similar blanks without the waste of cutting them the standard way.
Re: Coring a "Dowel" Question.
Steady
Jorge Casta�eda
Barry,
It sounds like a good plan, if you have a steady that really keeps the work centered; make a cylinder and go for it. Show us the results. I made twin goblets that way.
Doc Green
When coring an end grain piece, you must cut the core all the way off. You can not "pop it free" after cutting until only a small-diameter connection remains between the blank and the core.
If you try to pop it off, chances are good that you will simply pull the "plug" out of the bottom of the core. This happens because the wood fibers are stronger along their length than the sideways bond from one bundle of fibers to those adjacent.
I learned this the hard way. :\
~Doc
robo hippy
Like Doc said, you have to cut them all the way off, and can not break off the last little bit. As you found out, the bottom will bulge out slightly leaving you with a convex bottom, so plan a little extra weight. If you are going to core out a series of end grain pieces, I would suggest using your tailstock. With the McNaughton, and using the straight parting tool blade, the tailstock will not be in the way. With a long log, a steady rest might be handy as well. I once cored out a series of bowls from one cylinder, and it worked well, but I think that process is more suited to plate and platters.
robo hippy
Thanks, I was thinking about ....
Using the straight knife. I don't like coring them all the way off. Never had anything bad happen, but it sure looks like something that could get exciting.
I was arguing with my self over the thickness of the bottom. The one I did, I turned the bottom pretty thin thinking I was reducing the stress, but thicker might be better.
Turning an end grain bowl was interesting. All the cuts felt "funny" Some were really smooth though.
robo hippy
Another thought would be to dunk the end/base of the form in curing oil (Danish type, Watco, Deft, etc) for drying purposes.
The hardest thing about cutting a piece all the way off is having the cutter point at exact center. There is some flex in the tool, and if you ever have tried to remove the stub left from breaking a core out, you can see it move down. Raise the tool rest. When coring crotch, burl or end grain, I cut the pieces all the way off. Do turn the speed way down as the core starts to wobble.
robo hippy
