Movement: Guitar Pick Up - In Reverse
charlie belden
The "pickup" under each string on an electric guitar started out as a small cylindrical magnet with a copper wire coil wrapped around it - an electro magnet. As the conductive iron bearing wire string above it moves through the magnet's magnetic field, it induces/causes a current to flow in the copper wire coil wrapped around that magnet. The resulting current is then amplified electronically and the amplified current is then used to drive another electro magnet - in a speaker - causing a diaprham connected to it - tor move away from the magnet - and pushing some air. The resulting pressure waves in the air can then be heard. And if you were ever at a Blue Cheer performance - you know the resulting sound can also be felt ; )
BUT - WHAT IF . . .
you pulsed a current through the copper wire coil - that's wrapped around a cylindrical iron core? Could it move a horizonal guitar string directly above it and cause it to vibrate - and maybe even make sounds?
OR
you suspended a "ball and socket" pendulum above it? Could you get the pendulum to move if its "shaft" were an iron wire?
Some interesting possibilities to add actual movement to a piece.
comments. suggestions?
