Mustard paint: who sells it?
Aage Rendalen
Aage Rendalen
Superglue and general use has taken its toll on my 3520B. Where can I buy the touch-up paint?
Re: Mustard paint: who sells it?
Dick Hines
Dick Hines
I bet if you call PM they will fix you right up.
Bruce Stangeby
I have purchased paint directly from Powermatic. Give there customer service line a call and they will fix you up.
Jorge Casta�eda
On my neck of the woods, you bring a sample of the color you need, a computer reads it and makes a print out, then they mix it, very good match every time. Off the shelves, cadmium primer for galvanized is very close and comes in a spray can.
Jerry Hall
I do a touch up every so often too. I use a wire brush in my sander to clean things up a bit. Scrub down with lacquer thinner. By then I can't wait to order from Powermatic so I found Rust-Oleum Farm Equipment Yellow in my hardware store and it is a very close match. If I make clean mask-off lines and finish a surface I can't tell the difference.
http://paint-and-supplies.hardwarestore.com/49-266-industrial-spray-paint/rust-oleum-farm-equipment-paint-510944.aspx
But if you want the real stuff Powermatic sells a touch up paint in 12oz spray cans. Its called "Powermatic 6612060 Bronze Enamel. You can get it by calling there cust. relations number. 1-800-274-6848
Betty Scarpino
Re: Mustard paint ... or paint it yourself?
Betty Scarpino
Binh Pho is painting a PM lathe that was donated for a raffle in Saint Paul at the AAW symposium. The Chicago chapter guys will deliver it to Saint Paul. Free shipping in the US or $500 credit for shipping elsewhere. Here are two progress photos.
You could creatively paint your lathe yourself .....
Wow, that's HOT!!!!!!
JamieDonaldson
That is seriously cool.
