3520b Quesstion
3520b Quesstion
3520b Quesstion
Skip Beardsley
My new lathe is set up and running. Does the spindle lock have a fully locked feature like my Delta? When I push the button it will lock the spindle but I have to keep a finger on it to keep the spindle locked. This makes some operations very difficult.
Skip
Re: 3520b Quesstion
Re: 3520b Quesstion
Galen Vetterick
I think I have seen a posting for a home made hold down.
I could not locate on a simple search.
I thought they mounted a Quickset lever hold down clamp to the headstock just above the button and used it to hold in the button.
I hope whomever posted before can show you, as I recall a picture was also posted.
Sorry that's all I remember.
Re: 3520b Quesstion
Re: 3520b Quesstion
Doc Green
An easy way to get a hands-off spindle lock for the PM 3520 is to . . .
1. Permanently remove the bottom screw that holds the bracket around the spindle lock button.
2. Remove the top screw and place 3 or 4 washers between the bracket and the body of the headstock. When you replace the screw, leave it loose enough so that the bracket can swing from side to side. (You may need to use a longer screw than the original.)
To lock the spindle, press the button and rotate the spindle until it locks. Then swing the bracket over to hold the button in.
Many people have expressed a concern about starting the lathe with the spindle locked. I believe that's a minor issue because doing so will simply make the belt squeal for a brief instant, AND, you should not have the belt overly tight anyway; you want it to slip in case you get a bad catch or grab as frequently happens when I'm trying to core a bowl.
Re: 3520b Quesstion
Rob Wallace
Starting while the spindle is locked......
Rob Wallace
......shouldn't be a problem, because of course EVERYONE turns the spindle a few times so they're sure that rotation of the work will clear the rest, etc., right? ;)
Great low-tech solution to maintaining a locked spindle on the 3520.....I'll see if it works on the Jet 1642.
Rob
Re: 3520b Quesstion
Dick Hines
Re: 3520b Quesstion
Dick Hines
I just drilled aa hole in either side of the bracket and stick a piece od wire through the hole. The wire holes the button in.
Tie a piece of string to the wire and then to the lathe. If not you will always be looking for the wire when you need it.
Re: 3520b Quesstion
Dick Hines
Re: Starting while the spindle is locked......
Dick Hines
I drilled two small holes, one in each side of the bracket. I stick a piece of wire through and over the button. Tie a string to the wire or you will spend a lot of time looking for it.
Also if you look in the Feb issue of the AAW journal page 16 there is another way to solve the problem.
Re: 3520b Quesstion
Re: 3520b Quesstion
I've been turning on my Powermatic now for about 7 years. I've never needed to lock the spindle lock in position. When I was tips editor I got constant tips on ways to do this and always thought I would try one of them. I just never got around to it. I guess it has never been something I really needed.
There isn't a danger when turning on the 3520 with the spindle locked. It simply won't come on. The controller can apparently sense that something is preventing it from turning and nothing happens. I've done it a few times with the index pin inadvertantly left in.
