Sandblasting medium
Sandblasting medium
Steven Antonucci
Sandblasting medium
steven antonucci
So I finally bit the bullet with my Christmas dough and I bought a small sandblasting cabinet. Right now, I am using an abrasive called Black Beauty, which I think is a coal slag product. The local Tractor Supply carries a red garnet abrasive.
Anyone got any insight as to which abrasives work best with wood eatin'?
Steve
Re: Sandblasting medium
Donna Banfield
Don't use the black beauty in any light colored wood. It will stay in the grain/pores, and unless that's the look you're going for, you won't be happy.
I've used black beauty, glass bead, and a fine silica. You can also use pecan or walnut shells? Whatever you use, know that it will take a long time -- something that most woodturners are not accustomed to :^) You need a powerful compressor and a nozzle that has a small opening to concentrate the spray.
Steven Antonucci
Noticed that with the BB...
steven antonucci
too late :(
Thankfully, I have some practice pieces before I get serious, but the ash one has a dull grey cast from it.
Thanks
S
Re: Noticed that with the BB...
john lopez
I was wondering if a coarse grade of silica sand might be good.
Say a #1 or #2 grit.
There was a tip in American Woodturner from somebody who put sand inside hollow forms and left the pieces spinning at low speeds like maybe 100 rpm overnight.
No sanding by hand on the inside sounds good to me.
I'm not sure about leaving my lathe on overnight ...
I have enough trouble sleeping already but letting it run for hours at a time when I'm awake would seem okay.
I'm also curious about lava, pumice and maybe perlite as sandblasting abrasives.
I recently smoothed down an inlay section by hand with pumice that is sold in block form to scrape grills clean. It cut the CA pretty quickly.
Bill Neddow
Steve, I use a silica sand which I get from a company called Princess Auto here in Canada (equvalent to your Harbor Freight). Ask there, or at a body shop where they do sandblasting and you can get good advice. If that fails, look up the sandblasting companies in the Yellow Pages. I have found most people to be really helpful -- especially if they think they can sell you something.
Bob Rogne
I found that crushed glass is the best for using on wood. Slica was poorly graded and shell was the same but also a slower cutter.
Just what i"ve seen.
Bob Rogne WestMac Turnings
bill Crommett
John: Terry Daniels had a drum set up to turn for hours that he used to smooth out the internals of small opening jugs. Also the drum idea has been in use by the gem and mineral people for many years. In fact I have some silicon carbide in a couple of grits that has been sitting in the back corner of the basement for twenty years. Another "To-Doo" that got stuck in the time warp.
