Direction
OK, so you are apparently riding the bevel, cutting back toward the top?
Wouldn't put it that way because the cut is basically a shear slicing cut.
When you are working through a small opening, do you drill down so far, then start working your way from the middle back toward the top?
I do drill, but no, I will not go that deep to start hollowing. Depending on the form, I'll go a distance in then cut to the outside and back toward the opening when the Hunters are mounted; they will not cut with a push stroke when the cutter is set at an angle to the axis. I tried the straight holder with the cutter rotated up level to finish a bottom; it wasn't pretty.
I drill down, but then always like to start by thinning the edge from the opening on then carrying it on back. I used to have problems of things getting out of round and deforming, causing a grab, when I tried to come back up to far on the inside of thin walls.
Since I use a Kobra, I try to establish a wall thickness as I work down to the bottom. I then use the Hunters to clean up the inside ridges and bumps in light pull cuts that start at the bottom and move all the way to the top (opening end) of the vessel in a single pass. I do the same thing with deep bowls. I will most always cut to about a 1/4" thickness on hollowforms so as to prevent most of the flexing that you'd get with very thin walls. I don't lust for translucently thin walls, but can see where that might get to be an issue without some outside pressure to hold the diameter uniform, especially if you don't have a bevel to leverage and control your cut.
Let me ask. If you were turning an ovoid, or egg with the fat end out. Would you start by drilling in so far, then opening a hollow, that you then expanded, then worked your way toward a small opening?
Not sure I understand you, but to do an egg shape, I'd usually put the "heavy end" towards the headstock and hollow from the "small" end. If however, I wanted the egg to sit on the opening, I'd be hollowing from the heavy end.
