Sorby Spindlemaster
Thomas Norton
Saw this lathe tool on Highland Hardware site and wonder if anyone has any info on it?
Thanks
Sorby Spindlemaster
Thomas Norton
Thanks
Re: Sorby Spindlemaster
Mike Brazeau
I have a 3/4" version I bought at a Toronto Wood show about ten years ago after witnessing an awesome demo from a Sorby UK rep. Will give you a good deal on it! Has occupied a slot in my rack since then and rarely ever out of it. My skew skills improved by forcing myself to use one. In spite of what Alan Lacer says about them, I prefer the oval skews. Except for planing cuts, where the skew excels, I prefer a pointy ground spindle gouge for many of the cuts a skew can do on beads etc.
I wouldn't buy one
steven antonucci
you can probably make one in about 15 minutes from a round bar. Grind a flat on the top for maybe an inch? and a fingernail profile underneath. I made something like this a while back, but I don't use it.
S
I wasted my money on 1 many ....
JamieDonaldson
..years ago, and found out it's not even good for opening paint cans like a skew!
Richard Allen
I have found that the spindlemaster does exactly what it is supposed to do. As with most tools I find that there is a learning curve if you want to get the most out of the tool. The time spent on that learning curve might be better spent on the skew which is quite a bit more versatile than the spindlemaster.
The tool isn't a round bar ground in half as Steve has suggested. For one thing the "bevel" is highly polished and flat. To sharpen the tool you hone the top flat side only. That thin cross section lets you position the cutting edge into tighter spots than a skew. That highly polished flat bevel burnishes a very smooth surface on the wood while cutting. The tool works very poorly as a scraper.
The spindlemaster is NOT the holly grail of spindle turning.
It's a good tool.
Doc Green
In my opinion, it's an oval skew with a curved cutting edge. It's good for planing cuts on a workpiece several inches in diameter where the straight edge of an ordinary skew gets a bit touchy. It's also handy for V cuts, forming beads, and so forth.
I bought mine several years ago before I had gotten the hang of using a skew of any sort. Thought it would solve the problems I was having. No joy. After I ripped up several spindles, I put it aside. Later, tried to give it away. Couldn't. But recently, I got it back out and it does a good job. Don't know what happened to it while it was laying idle, but it works now. I use it frequently.
~Doc
charlie belden
I have the 13 1/2 mm (a bit over 1/2")wide 4.75mm (~3/16") thick SpindleMasterand found it to be a great tool for tansitioning to a curved edge skew. For spindle turning up to maybe 2" diameter, it works well for beads and coves and can be used to do long narrow finials It will get into tighter spaces that a skew since it has basically a single bevel. While not Catch Free, it is less proned to catching than a straight skew or cuved skew - or a spindle gouge for that matter.
As noted - you never grind or sand the "bevel". Sharpening is done by honing the flat top.
The one drawback of the 1/2" version is its thinness. It quickly becomes a chatter like tool when extended more than about an inch passed the tool rest.
When I bought mine, it was only about $25, a veritable steal when it comes to turning tools. Loaned mine to an instructor at WoodCraft who was having difficulties turning beads and coves with a skew. She liked it but couldn't afford to buy one (apassionate about woodworking but as is often the case, thin on cash). So I bought one for her. Figure it was a Support The Arts thing - and lord knows artists can use the support.
Now that I use a skew a lot - would I buy another SpindleMaster? Probably yes.
Dick Hines
Detailmaster? looks like a scraper to me.
David Walser
I guess I'm in the minority. I have a spindlemaster and I like it. I was introduced to the tool when I took a week long class at CSUSA in 2003. I was told it was easier to use than a skew for planing cuts and for turning a bead. I've found that to be true. It's less prone to catch and I find I can turn a bead with a more consistent radius (going left and right) then I can with a skew. Like a skew, it leaves a very nice finish.
I still like using my skews, but the spindlemaster is a valued part of my arsenal.
My only problem with the tool is I wasn't told how to sharpen it. So, I tried to touch up the edge with my grinder. Big mistake. Fortunately, someone came up with a "formula" for sharpening a spindlemaster using Tormek's SVD-185 - Articulated Gouge Jig and I was able to restore the original cutting edge to my spindlemaster.
Ken Vaughan
My wife gave me one so of course it is a great tool. I do use it more as a shear cutter. Best description I know of is as a flutless gouge.
I do lightly grind and hone the lower bevel and it performs well.
I expect it is a better beginner/intermediate tool to build some success while learning the skew, and probably led met to a preference for a oval skew (but the other kind with rounded edges does nicely.
Even though I am a tool junkie -- I have only one.
woodspinner
Been using one (3/4) for 9 or 10 yrs now.I turn pens,handles,all spindle work and especially finials with it.It's a love or hate tool for pumals you can't beat it cleanest cut I've had square to round.
charlie belden
Don't know where "detailmaster" came from.
May look like a scraper - but it cuts like a skew. It can be used like a scraper as well.
robo hippy
I took a class with Allen Batty once. According to him, it is a Sorby version of one of his tools, which was a skewchigouge type of tool. According to him, "they got it all wrong." I used his version which was made from round stock. An excellent tool for beads, coves, and cutting across end grain. I have a set of them, and can get them into some places I can't get a skew into (yes, the old hippy does use skews once in a while). I agree that they are too flimsy.
robo hippy
Re: It's a good tool.
Lan Brady
Doc,
I bet the tool studied real hard and practiced every time you were not in the shop. It wanted to show you how much it had learned so that you would like it again! It seems to have worked.
Lan
Musta found the prototype
A. Kapocius
About a dozen years back, in my quest to find rusty tools at flea markets and estate sales, found one such tool. Made from a thick file 'cuz not all the surface was ground smooth. I showed it around at the time but the best guess was that it would cut aggressively. Guess I was too wary to try.
Onliest thing I could guess was that it was for scraping Babbit bearings.
Al Kapocius
