Proxxon jigsaw (STS 12/E) ?
Dave Belser
Do you have/use one if so any comments or advice?
Dave Belser
Re: Proxxon jigsaw (STS 12/E) ?
I looked at them but ended up buying an air saw. They are designed for body work. I'm amazed how easy it is to cut wood with this thing. It's like cutting butter. Uses up a lot of air but you don't need to use it very long.
Frank Sudol purchased a small jigsaw from Micro Mark tools. It worked well. I've looked at the jigsaw attachment for the Dremel. I think it would probably work also but haven't used one.
Dave Belser
I'm looking for a small reciprocating saw that I can mount to my metal lathe. It will need to cut through about 1/4" easily. I don't have a great air system at this point and I'm on the broke side.....
My compressor is a small portable double tank thing. How much does the air saw cost? It looks like a a proxxon setup needs a transformer and will run about ~100+ for a full kit.
- D
