Tool making tip
steven antonucci
In reading Brad's post below about the tool handle coming lose in a demo and the tool spinning in the handle, I thought I'd share what I started doing on the tools I make.
I used to glue them with CA or epoxy, but if you are turning handles from green wood, sometimes the CA will cure from the moisture before you can get the tool fully inserted. Epoxy seems to not want to stick too well.
For starters, I drill my hole 1/64th small if I can. My lathe won't drill an accurate hole to the exact diameter of the steel anyway, so slightly undersized makes for a pretty good fit. If the tool is an offset cutting tool (i.e. cutter in a hollowing tool or swan neck...), I grind a very small spur on the end that is going into wood, and I seat it with a mallet. 1/8" is plenty, and it doesn't need to be perfect like a spur center- it just has to engage the end grain.
Steve
