REAL MILK PAINT
What is the biggest problem you ...
Ed Moore in SW VA
had while doing a demo?
In the biggest demo that I have done the lights were placed in such a way that I could not see what I was turning due to the glare. I had trouble turning an icicle and I suddenly realized it was because I couldn't see it and how I was presenting the tool. So, I suggest that if a demo is being projected or recorded, make sure that the light placement doesn't interfere with the turner's vision.
Ed
Re: What is the biggest problem you ...
Michael
Michael
If you think you'll need to sharpen during a demo, bring your own. Do not rely on the sharpening/grinding setup of the host unless you've checked it out beforehand. Same with the lathe, if you're not bringing your own then be prepared for all sort of interesting challenges. Also, be prepared for the one or two guys, usually in the back room who talk non stop. Those guys do this at all demos they attend, it's not you it's them. Stopping, looking at them and saying something like "What's that, I didn't quite hear the question?" will sometimes work.
Doug Thompson near Cleveland
When the lights were turned out so they could see the glow from the light shinning through the wood... the problem was I had a tough time seeing the tool. The only thing that saved the demo was I turned in the dark at home and kept my head.
This year at the AAW symposium I thought I had planned for every eventuality. I brought inserts in all sizes for my chucks i had my own drill chuck. I've forgotten my vicmarc chuck key twice at other demos, fortunately it's a 10mm allen so I was able to get one on site and saved those demos. I thought I had it all and was prepared.
The put me on a ONeway. They told me I would be on a Powermatic which is what I use at home. No problem. I had outsmarted them because I brought my m33 adaptor for the chuck.
Guess what. I brought the wrong jaws for the threaded 2 part ornament demo. No problem these jaws go down really far. Worked well for one end of the piece however the tenon on the other side was too small. I ripped up some masking tape from the floor that was holding the cords down and wrapped the end. Problem solved.
Well almost. I started to drill out the inside of the ornament and had forgotten that ONeway's have a #3 morse taper. My room assistant saved the day and ran and got me a chuck with #3 taper.
All went well after this. Hollowing went smooth, the threading went well but then I got to thinning out and shaping the top. All of a sudden I saw a mark. No one else noticed but I knew what happened immediately. The masking tape tenon must have pulled things off center very slightly and I had cut through into the inside.
I stopped the lathe and told the class. When ever you hear or see anything strange at the lathe stop and look and see what happened. It is a safety measure. I rotated the wood to show them what I had done. Then I told them this is just in case you put something live inside the ornament. It will be able to breath.
I did a demo on coring bowls with the McNaughton system. Prepared the blanks after practising on a bunch at home. Used up most of my blanks and was left with three Bradford pear blanks. Bradford pear turns like a dream, but I had never cored it before. Turns out it is brittle and the chuck foot broke off each blank as soon as the knife touched the blank. Very short coring demo.
So, Practise on the exact same wood you plan to use in the demo.
Keith Tompkins
keith tompkins
John, the same thing happened to me in Lousiville.....there was a General in the demo room; as I was setting up, a crew came and took the General and replaced it with a Oneway....I think....HEY, you were one of my camera guys, come to think of it! I have learned to carry as many adapters as I can, although switching over takes time. Once I had all adapters, but couldn't get the adapter out of my chuck. In Hartford, I got a catch with a skew...touched the wood before securing the tool to the rest....dumb mistake with resulting ribbing. No explanation will stop the chuckling.
Dick Wilson
In my guild people sometimes bring in partially turned pieces that got away from them or they lost vision on can be done with them. Some are firewood. Others I have taken home, looked at for a period of time and come up with a game plan. I take them to a meeting and the original turner is impressed.
During a hollowing demo by another member he gave me a butchered partly turned piece and said "Lets see what you can do with this". I proceeded. It was elm that was harder than concrete. I didn't get very far and I blew it up. Guess I will never live that down. Personally I think it was a set up. :\
Moral to the story: Use your own wood, know what you are putting on the lathe.
Steven Antonucci
Did that make sense?
steven antonucci
When I first started demonstrating, I would use my sales training to make sure that folks were "getting it"? In sales, it is far better to ask a question and shut up than try to explain it infinitely.
Except when you are talking to a bunch of turners.
I found myself being stared at and vaguely nodded at. I knew that I had presented something unclearly, either in words or understanding. When you know what you are doing, it is sometimes not obvious how to explain it and sometimes, you flub the words. Other times, you find yourself relying on an understanding of some background information that the audience doesn't have.
Turners are a funny bunch. A lot of people won't say that they didn't get it. So I started making mistakes on purpose to test the waters. Once in a while, someone would stop me. If they do, I let them explain what I did wrong, or "correct it" to the audience. Often, hearing the same thing twice from two different people will result in more people getting it.
Once I realized this, I started doing asking questions at other people's demo's. Some cases, they are "for me", but most of the time it is because I think that they said something vague and I know that half the audience missed it. It stops the demonstrator and makes them repeat or expand upon something that is usually pretty important.
Try it sometime.
Steven
Peter Charles Fagg (UK)
Totally in agreement, nothing worse than some of the audience talking!
A word now and then OK but deep conversations!!!
I usually say something along the lines of "You realise that you are paying me to be here?" either that or I just stop and wait whilst staring at them, when they realise that I am not talking they stop too, then I say "Can I continue?" or "is it something you would like to share?"!
Regards Peter
Mobile phones ringing!
Re: Talking during demos
Wayne Kuhn
Before the demo our pres will announce to the membership, If you need to talk please take the conversation out of the room. If a conversation breaks out during the demo, Mr. Pres will politely interrupt the demonstrator and ask the offenders to take the conversation elsewhere. This saves the demonstrator (our guest) from correcting the bad behavior of our members (the host). This happens during the more interesting demos. You turn to the person next to you to whisper your amazement at the technique being shown and the next thing you know your in a full blown conversation. DAMHIKT.
Brad Vietje
Brad Vietje
Oh gosh...
I was going to respond under the "worst demo", or "what makes a demo bad". I've done some really good demos that I thought went just right. But the worst demo I ever experienced was one that I presented in Albany a few years ago. A whole bunch of stuff went wrong, and it was simply awful! A few people on this forum were there, and it did not enhance my reputation as a skilled and entertaining demonstrator!
The short answer is that I gave a miserable presentation that included three mysterious bad catches making "finishing" cuts at the opening of a hollow form -- the same cuts with the same tools I use all the time at home. The first was with my trusty 3/8" Pro-PM bowl gouge, which surprised me, but since I had not slept well, I figured I just needed to push through and do it right the second time. That didn't help, as I got another (worse) catch a few seconds later. Then I switched to my 1/4" bowl gouge that's one of my 2 go-to tools when I really need it to cut perfectly.... and I got another catch on the inside of the rim, which sent the piece flying into the metal screen instead of the front row(lucky me!). Holy smokes !?! What's going on???
Turns out that in setting up the night before I made a fatal decision. Being a small-town country boy, I decided to bring all my tools up to my room for security, figuring they might be stolen in the big city of Albany. My tools usually spend the winter in an un-heated barn, and I later realized that the forced hot air heat at the hotel had dried the wooden handles enough that the tangs had come loose, and when making a back cut in my usual way, the tool had rotated in the handle, causing the fatal catches. I now whack the end of the handle and apply a drop of CA where the tang enters the handle just to be sure.
Here's a partial list of what else went wrong:
* I had very little sleep, for multiple reasons (I don't sleep well the first night in a hotel, and was also kept up with a fresh and painful shoulder injury), so I was primed to screw up.
* I was emotionally distracted by the knowledge that this was the first demo I'd done without my dad there (he was my turning buddy, had died of cancer a few months earlier).
* I tried to show too many things in the time allotted.
* I discussed too many tools, and there was not enough room to spread them out, so a few rolled onto the floor.
* The demo lathe was on casters, and not very stable, and thus about 4" too tall. It was left like that so I could turn it around to show hollowing with a laser to assist in measuring wall thickness, and I wanted the audience to see the laser light on the side of the vessel. Unfortunately, the needs of the camera operator (oh, GOD... its actually on tape somewhere...) dictated that we leave it up on casters... I should have put my foot (and its legs) down.
I'll remember that demo as long as I live, and I've learned a lot from it. I've done some very good demos since then, so it was not the beginning of the end, but I always create my handout and prepare with that demo in mind, reminding me how bad a demo could be if I don't plan for a big success.
Who knows ? Maybe they'll even let me come back to Albany someday! ;)
Safe spinning,
Brad Vietje
Newbury, VT (9"-13" more snow coming tonight...golly, what fun!)
steve worcester
The first square turning demo I did, I started to sand and sheered the face right off the mandrel with the spinning edge.
Did a demo at the Rocky Mountain Symposium and went through the bottom, inside met the outside. Usually the audience is empathetic, your human and showed you are like them, you make mistakes. Still, bad time for it to happen, but you move on and make the best of it.
Keith Tompkins
keith tompkins
Steve, I was turning one of my dancing boxes, when someone in the audience asked...what if you get a catch way down inside? I replied...."What's a catch? I dont' think I ever had one." It was good for a good laugh. Yep, I restarted the lathe, and proceded to cut my turning in half. >(
