If you goal is to reproduce ripples, yes
steven antonucci
Way back in the day, I designed audio equipment as an electrical engineering student. The one issue you will have is that you need to allow air to pass from front to back of your cabinet, which is why guitars and speaker have holes in them. If you don't, conceptually, you'llbe pulling against a vacuum.
By using styrofoam, you may get air to pass through the membrane and solve this, but I see it as more like a shaker table. I think the micro beads may work themselves into the foam, and plug up the air passages. All of this is guessing, of course...
I would probably make a thin membrane out of spruce if I wanted clear sound, or maple will do if you just want the waves. You can do it by turning a disc first, and then a backer plate with a very shallow recess in it. Simply insert your disc into the backer plate and turn it down to the recess flush. I made a disc for someone to pierce that was only .020 thick and 14" wide like this (you can almost read through it).
Perhaps a small, decorative sound hole at the bottom (more like a djembe?) than a bowl?
I watched your video, so I think I know what you are after...
Good luck.
Steve
