Ironwood boxes
Ironwood boxes
Ironwood boxes
mjonesrdg
A pair of ironwood boxes sitting on a chunk of ironwood. In the 3" x 3" range, lacquer sanding sealer...buffed...and Ren wax.
Perhaps more of interest, is the second pic which shows how I "Jonsied" the joint which will only allow the lid to be closed in a precise grain-matched position. I have done this extra operation several times and the lady at the gallery seems to appreciate the extra effort.
The process is simple and pretty quick. Instead of a mortise and tenon, I cut two mortises and a separate ring that will be cut in half...part inserted into the box bottom, and the other half into the box lid.
Love to hear your comments.
Re: Ironwood boxes
Re: Ironwood boxes
fgvanatta
Beautiful work. I especially like forcing the lid to only sit in one position.
Frank
Re: Ironwood boxes
Leo Cuellar
Real Beauties.
Leo Cuellar
Re: Ironwood boxes
Re: Ironwood boxes
Sam Scalzo
Very well done. I have never tried your idea may have to.Sam
Re: Ironwood boxes
Steven Antonucci
Auto-align feature!
steven antonucci
Neat that you figured out a way to have the grain auto align by keying the lid!
Is the ring cut from another aread of the box? It also looks like it is grain matched?
S
Re: Ironwood boxes
Re: Auto-align feature!
barry Ward
WOW.beautifull work
Re: Ironwood boxes
Sharon Doughtie demo'ed using very small rare earth magnets to keep the lids aligned on her boxes. She drilled holes inserted the magnets slightly below the surface. Then she filled the holes with sawdust and glue. Of course there were matching holes in the lid and bottom. I thought that was a nice touch.
What you have done is also an excellent idea and very simple. I made locking bayonet type lids for a few projects using a technique similar to your split ring. It was a pain. I like your idea or the magnets better.
Re: Ironwood boxes
mjonesrdg
The first piece that I cut after establishing tenons at both ends of the blank will become the ring...so I guess technically it is wood from the lid more so than from the box.
Re: Ironwood boxes
Re: Ironwood boxes
charlie belden
LIke you, I enjoy doing precision turning - pop fit lids, finial blended into lid, parts inside of parts, etc.. But this auto-alignment thing, while technically interesting, seems a bit authoritative and a tad condescending - Das Lid MUST Be Aligned DIS VAY - And ONLY DIS VAY!
Pop fit lids impress the hell out of other turners - but require two hands to remove - and sometimes - due to wood expansion - even two hands won't get the lid off. A looser fit permits one hand lid removal - but also means the lid can fall off. A pair of magents gets you around the latter but still requires two hands.
As for proper alignment of lid to box - with prominent grain the correct alignment is obvious. And the easier it is to rotate the lid to get the grain to align the more apt people are to get the alignment right. And people seem to enjoy being a participant - interacting with a piece
(this response may just be the Vicodin talking. had a tooth yanked out and a titanium screw installed in its place yeterday and I'm trying to stay well ahead of the "slight discomfort" I know is lurking about waiting to stick me to the ceiling ; ) )
Re: Ironwood boxes
Brad Vietje
Re: Ironwood boxes
Brad Vietje
Nice!
Nice boxes, beautiful wood, and an interesting way to get the figure aligned.
Can you elaborate o the wood? "Ironwood" tends to be the hardest or toughest wood in any given location, so it could be used to describe over 30 different species, depending on the location. Around here, Ironwood is Eastern Hophornbeam (Ostrya virginiana); in Europe I understand it usually means European Hornbeam (Carpinus betulus), while in the Desert Southwest of the US and northern Mexico, it would refer to Desert Ironwood.
Can you tell us more about your local variety?
Thank you kindly,
Brad Vietje
Newbury, VT
Re: Ironwood boxes
May I forever be known...
mjonesrdg
...as DAS BOX NAZI!!! :D :D :D
Re: Ironwood boxes
Re: Ironwood boxes: species?
mjonesrdg
Brad, I didn't cut the tree/bush myself so I must trust my benefactor's word that the wood came from Baja California. It matches what I have turned in the past and called desert ironwood...right down to the stench if you get it hot.
