Finishing with grout?
Keith Newton----Little Rock, Arkansas
I have got a carved turning going out of Catalpa that I would like to have an archaic look. I have never used the grout before.
What tips can someone share with me.
Do I apply before the wood is dry? Do you use any stain, and when?
How thick, and what do you apply it with? do you leave a lot on, or wipe off most?
This snap was taken before all the carving was done, but I intend to leave the bird identity obscure, without trying to accurately make it a dove or eagle.
It is about 12" T, and ~ 231 cubic inches volume.
Re: Finishing with grout?
Are you sure you mean grout?
Grout is not really a finish. It is used to fill in spaces (in tile usually). I use it to fill in thin voids. I've also used Drywall mud.
What you may be looking or is Gesso. It's a thick bodied paint basically.
Can you tell us the affect you want.
Ask Clay Foster about grout
arkie
Re: Are you sure you mean grout?
Keith Newton
For quite some time, I have admired some of the native American effigy pots from around here. While they are crude and simple, that is a lot of the appeal for me.
I guess I would like for it to look like it had been dug up out of the ground, after having been buried for a long time.
clay foster
Keith,
I use tile grout to fill in carved areas and around elements such as wire and brads to give the object an old artifact affect. It also fills in the pores on coarse grain woods such as ash and pecan. I recall catalpa as being an opened grain wood, also.
I use it after the wood is dry, so the grout won't pop off after the wood has shrunk. I use the grout as is from the bag, bit it comes in an array of colors. I use white to fill in on wood that has been burnt. Mix it to the same consistency as you would use to grout tile, about like toothpaste. I just rub some on with my finger, let it set for a while, and wipe off the excess.
After the grout is dry, I use very light amounts of brown shoe polish to give a low sheen. You can use any kind of finish you want, but real shiny is probably out of character for the effect you want. It's always a good idea to do test samples.
I've included a picture of a bowl that has tile grout as an element.
Clay
"I have got a carved turning going out of Catalpa that I would like to have an archaic look. I have never used the grout before.
How thick, and what do you apply it with? do you leave a lot on, or wipe off most? "
Thanks Clay, That is what I had in mind.
I'm anxious to give this a try. That sounds easy enough, although I am thinking that I might try two different colors on this project.
