Can't remove hunter (Jamison)cutter
Aage Rendalen
Aage Rendalen
I find it hard to believe that you can strip out the screw that holds the Hunter-Jamison cutter head, but I can't remove it with the special tool designated for the task. Anybody else been up against this problem?
Re: Can't remove hunter (Jamison)cutter
Not yet but here's what I would do. First put some liquid wrench on it and let it sit overnight. I'd put the penetrant on both sides of the screw just to be sure. Then carefully grind the end of the tool so it's good and sharp. Then push down very hard and twist. It's important not to lean the tool. I have had luck in the past actually gluing the tool to the screw using epoxy. Put a small drop in the head after you clean it with alcohol. Clamp the tool in place and let it cure. Then come back tomorrow and put a lot of downward pressure on as you twist.
If that doesn't work it's time to try an easy out but on that size screw that might be interesting.
Make sure that you have removed.....
JamieDonaldson
...any material in the screw hole that can prevent inserting the wrench all the way to the bottom.
Bill Turpin in WNC mountains
Mike Hunter has seen this enough that recent #1 tools have a T9 instead of T8 screw. Same outside diameter but larger tool hole. I would recommend putting Neverseez on the thread before initial use.
Lyle Jamieson
Lyle Jamieson
Yes, in the last couple years I have changed from the #7 to the #9 torx (larger)screw to try to help it from getting stripped. Great suggestions so far if you get it stuck. Great idea John had to glue the wrench in the socket. Hope it works.
The key is to not get it stuck. If you use the carbide cutter regularly remember to change the position of the cutter by loosening the screw and putting the cutter in different places every time you start a vessel. And when you tighten up the screw it does not have to be tightened real tight, just finger tight. The shaft is machined to close tolerances and the torx screw is tapered to fit well inside the cutter. This will keep the edge used in a sharp position as well as keep it from getting stuck.
If you plan to store it for long time periods use some WD40 to prevent it from rusting in position.
Keep me posted on your progress so we can get you back in action with new parts.
Keith Tompkins
keith tompkins
Try this, make sure the torx head is free of debris as Jamie said, then insert the tool. On a solid surface, tap the tool lightly as you apply slight rotational pressure. Worst case, spin the entire insert....it should turn the screw with it.
Aage Rendalen
No luck; it twists to the right, not left
Aage Rendalen
The key grips to the right but not the left. Mike Hunter called and offered to replace, and as you've seen, Jamison also made the same offer. That's the great thing about doing business with the people in this business. They're stand-up people.
