I have 100% recollection of buying our fridge when we bought the house. It is 15 years old. Recently, it began to shudder when the cooling cycle ended and the compressor stopped running.
So, two questions:
Is it user servicable? (or better said, is there something simple I can do to make it stop?)
If I need a new one, is there any sense in stealing the compressor off of this one to make a vacuum system for the lathe?
S
Re: OT:Slowly everything is failing: Fridge shudders!
Walt Bennett
That could be a very simple thing - usually the motors are mounted via rubber doughnut anti-vibration thingies that will deteriorate over time. Yours is old enough that they're probably just about gone, leaving the motor mounts loose. Good luck digging through all the accumulated 'stuff' around it all though (hate that part!).
...about an average life cycle for a refer. A current model would be more energy efficient, and recycling the compressor for vacuum is possible as I recall, but have no experience there.
Re: OT:Slowly everything is failing: Fridge shudde *LINK*
Richard Allen
So Jamie got me thinking about how long things should last. I found this web site detailing just that.
Reading the list everything in my home is way past it's life expectancy except the furnace, AC, Hot water heater and washing machine. Those items have been replaced in the past 5 years.
Skip Beardsley
Steve,
If it dies you might want to think about turning it into a kiln for drying bowls, if you don't have one now. Several folks I know have done it and doesn't seem to be too difficult.
Skip
Bill Turpin in WNC mountains
Good recommendatin on the mounts. Unfortunately there are motor mounts on the inside of the compressor also. Most refrigerators have a cooling coil underneath. It will taper towards the back. If you haven't cleaned it in ten years, do so. The BORGS sell a long taper condensor cleaning brush in the appliance dept. There is probably a fan in the left rear bottom. Clean it also. Make sure it turns when compressor is running. Check the fan motor's mounts also. If you have only a coil on the the back, clean it and make sure that it is at least a 1/2" off the wall. Reduce the cycling. Decide what you want and where it is before you crack the door. TRAIN everybody in the house to do this. Don't let the kids decide on snack time while they look at everything dumping all the cold out! All the above: lowers amp draw, reduces head pressure, saves money, and should be done annually.
I usually try to read all the replies before I write something, but I'm not even going to look. Buy a new Fridge! No one should continue to use a 15-y.o. fridge if there's any way you can afford to replace it. A refrigerator that's 15 years old will use at least twice as much energy as a new, high efficiency model. Since a refrigerator is one of the biggest energy hogs in the modern American home, it can make a big difference. Don't put the old one in the garage to store beer for cook-outs, get rid of it.
If you find a way to use the compressor for some cool shop do-dad, that's a bonus, but as a fridge...? You can unplug it and use it as a place to store dry goods like grains and flour to keep them away from mice, a cabinet for storing finishes, or even turn it into some sort of bowl drying kiln.
Safe spinning,
Brad Vietje
Newbury, VT
Ed Heuslein
Steven, since nobody else has answered your question about using the compressor as a vacuum pump, I'll throw in my two cents worth.
It would work and draw a good vacuum. However, the CFM is so small that it wouldn't hold most pieces on due to leakage through the wood. One of my friends made one from an old refrig and that's the problem he ran into.
I'd keep the motor, toss everything else except the box itself and, as suggested above, make a kiln out of it.
As a matter of coincidence, our refrig started the same thing a couple weeks ago. I'm waiting for a good sale on a new one.
