I have a relatively new issue with my garage door. It lowers in a funny, jerky motion and closes completely on the left side, but the right side is perhaps 1/2" from the floor. The pin in the wheel on the left bottom gets pulled out(Side that closes).
I assume it is because the door is "crooked" in the frame, but it's the same door I've had for 15 years. Is there some way to adjust the tension in a garage door system?
Is the door a torsion-spring system? If so, your next step should be to call a competent garage door contractor to make the adjustment. If no major parts are needed, the adjustment will be fairly quick and not too expensive.
I had a similar situation a few years ago, and you should be warned that the torsion spring has a HUGE amount of energy stored in it. So much so that sudden release can cause serious injury or death. On my garage door, some of the set screws had loosened through use, and the tension on each side of the door became unbalanced because one of the end-keepers had slipped around the main rod, causing a situation similar to the one you describe. I was not going to deal with this myself, given good advice I had received from a friend, to not mess-around with the torsion spring. It requires some know-how and experience to safely release and re-tension the spring so the door closes correctly. I do most of the other maintenance and repair on the door (new wheels and guides, lubrication, etc.) saving money there, but tensioning and adjustment should be done by someone who really knows what they are doing.
Just sending you the same advice that I received, given that I would like you to retain all of your extremities in working order, and maintain that important condition we call 'life'.
As Rob has said not a home handyman job. We have a fellow in our guild who did it full time and even then he talked of injuries that service people encountered working on springs. One thing you can do is put spray lube on the track and rollers to make them track easier and even wd40 on the spring surfaces. If they rust they bind as they contract. Beyond that no mechanical adjustments on that portion of the door are home owner stuff.
I didn't have any problems when I adjusted mine. I simply figured out which way to have the door when the tension is least. I released the tension that was there and don't remember it being very difficult. Then I made an adjustment of the pulleys on each side, re tensioned the spring and tested it. It took a couple of tries but really wasn't hard.
Cable, some pulleys. The middle is the main system with a chain.
Not sure if that's the torsion spring you mention, but yeah, I know about how much energy they store. The one spring broke about a year back, and I swapped it for a new one.
Steve, you probably should have replaced both springs, even though only one was broken. Murphy's law says they won't both break at the same time. Surprised your repair man didn't suggest to do it. It is standard proceedure with most door repair people. Jerry
From your description you seem to have TENTION Springs, one on each side not a TORTION spring wound around a shaft over the top of the door. (The advice to leave the torsion spring to a profession is good, leave it alone unless you really know what you are doing.)
On your tension springs, they should be under little or no tension when the door is all the way up. You may have to release the door form the auto-opener and push it further up. once the springs and cables go slack, you can work on them fairly safely. Block the door in the UP position so it CANNOT plunge down on you when you are least expecting it. A C-clamp in the track will do a good job of restaining the door. You can then shorten the cable on one side or lengthen it on the other. Also check the track and wheels for damage and debris. When mine does this it's usually a piece of crud under the door or sticking tot he bottom of the door.
(If you disconnect the springs and let the door fall on you it could easily kill you, be careful.)
You probably should have replaced both springs, they need to be matched and even if the old one is nearly identical tot he new one, it may have a few hundred cycles on it causing it to not be as strong as the new one. This does not explain why it worked for a while.
Torsion springs are located across the header of the door. Tension springs are located one each side along the upper track.
I am surprised that if you replaced one spring a year ago you could get it to work well for a while with one 15 year old weak spring.
The least amount of tension is on the spring with the door open on tension springs. If you try to adjust the spring tension the door must be BLOCKED OPEN because it can fall while adjusting with dangerous results.
I would imagine you need to start by replacing the old spring with a new one. It would just be guess work on setting with one old and new. You need to match the spring length as a calibration when you preload it while the door is up. If you do not have the manual it will be a guess as they usually relate preload to weight of door since they vary so much. Mine you need a block and tackle to preload the spring and then bring up the slack in the cable and tighten.
From one who failed to block the door and had his fingers wraped under the cable on a pulley. I was lucky they just turned blues for a long time.
Sound like you have been there before too. Mine needed to be preloaded even when blocked clear back as it was an old double wide solid wood door. HEAVY!
Think it should have had heavier springs to start with.
When we bought the house years ago, the garage door must have been recently installed. As it turns out, there was an extra spring. A while back, one of the springs broke (with what sounded like a gunshot), and so I immediately grabbed the other one, and swapped it in. If I didn't have it on hand, I probably would have called someone. It only took about 5 minutes.
Sounds like I might be getting to the point of having a new opener installed.
..the door rollers are moving in the guide rails. Its not unusual for seasonal movements in the door frame to cause tracking errors, and most of the mounting brackets have adjustment slots for the bolts holding the rails.
All this reminds me of a time about a hundred years ago (plus or minus - 50 ) when I bout a new heavy garage door wholesale from a dealer out of territory.
He told me which spring was the right hand one and which was the left but I messed up and got it backwards. So after undergoing the dangerous job of tensioning, I had to take the assembly down and start over. After finishing that job I was quite proficient at spring tensioning and helped three of my buddies put up garage doors.
