REAL MILK PAINT
Practicing with a chatter tool
Barb Siddiqui
Barb Siddiqui
Trying some different things with a chatter tool, on 2 - 1/2" pocket mirrors. Now I have to learn to combine colors and divide them with V-grooves and such. It's Fun!
These are done on silver maple, with 2" mirrors.
Re: Practicing with a chatter tool
Steven Antonucci
Can't tell from picture, but is that end grain?
steven antonucci
My personal experience is that end grain chatters more evenly. I use a small skew hung over the tool rest...
S
Barb Siddiqui
Re: Can't tell from picture, but is that end grain
Barb Siddiqui
I believe it is, Steve. It's from the big silver maple tree felled in our yard last spring, and I had so many chunks and lumps cut around splits from big pieces, that I'm really not sure. But I believe it is. You use a Skew for chattering? That sounds tricky!
Good job. I love chatter work. I watched Micheal Mocho this weekend. He is a master at chatter work.
Steven Antonucci
Chatter with a skew is easy
steven antonucci
I thought I made a chatter tool once, but I couldn't find it when I looked for it last week. Instead, I grabbed a 1/4" skew. It might be 1/8" thick? If you set your tool rest a little above center, and present the skew flat across the face like a scraper, it will chatter.
You can vary the angle from flat to about 45 degrees, apply more or less pressure, change the overhang, etc to get different patterns. Here are some tops I made last week for a charity that we fundraise for:
The two on the left are chattered using the skew... Looks great, but makes them wobble when you spin them (which makes me nuts!)
Steve
Re: Chatter with a skew is easy
Michael Mocho used what looked like a 3/8" skew held so about 3" hung over the tool rest. He cut at about 7 oclock on the piece. It worked great.
Barb Siddiqui
Barb Siddiqui
That worked well!
Barb Siddiqui
Barb Siddiqui
Thanks John. Sounds like you had a great symposium.
