Ebonizing finials
Ebonizing finials
Jim Evans
Ebonizing finials
Jim Evans
I have a question about ebonizing finials. I have seen what looks like a gloss finish on ebonized finials that make me wonder what was used as a finish.
I'm thinking if a black glossy finish is wanted why not just use gloss black lacquer to begin with?
What do you use as a finial finish?
Re: Ebonizing finials
I don't see why you couldn't use glossy lacquer and just spray it on. My thoughts would be that it would look plastic. I dye my finials with black shoe dye and then spray them with lacquer. I buff the final finish with the Beal Buffing system. I think it gives more depth and takes away some of the plastic look. If I have any black lacquer I'll give it try later today.
Charlie Drake
Jim, I've tried glossy black lacquer and it looks like plastic as John suggests. After that fiasco, I went back to black deye and clear lacquer-much better.
Steven Antonucci
One more person ask why I put the black plastic...
steven antonucci
finial or handle on my wood box/hollowform/whatever, and I'm going postal...
Worst part is that I used to get this when I used real ebony or blackwood. I'd carefully explain that there were exotic species that were all different colors. No one ever asked me what I dyed the pink ivory with!
Steve
When does ebonizing become painting?
Dave Belser
I've had good luck with India Ink. You need to let it dry out a bit and/or blot it on. It's very easy to just wipe it all off if you are impatient. You can even buff it up with some cloth after it drys and get it quite shiny.
At this point it's my preferred method - It's water based (no nasty chemicals / cleaners) and it very forgiving - easy to add more or take some off to even it out if needed.
Not to hi-jack this thread but when does ebonizing become painting? Several people have mentioned paint. To my mind, the point is to make some other type of wood (cherry is a good choice) look like ebony. So when you ebonize you want a *little* of the grain to show through so it looks like wood.
The problem with this is that a lot of real ebony parts are finished to the point that they don't look like wood at all. So as some have said, why not just use any dense consistently black man made material or heavy lacquer/paint?
It would be interesting to see a bunch of different real ebony parts with different finishes, next to different ebonizied parts.
Richard Allen
Re: One more person ask why I put the black plasti
Richard Allen
I find Ebony is so nice to work with. The way it cuts is extraordinary. The amount of detail ebony will hold is fantastic. Sanding ebony is more successful than any other wood I have tried. A problem area I have found is that ebony can be brittle. But for finials I find ebony is a perfect wood.
Bill Howatt
I've used black marking pen and India ink. India ink works better IMO.
After drying, I've applied LV Turners Polish which is a friction polish.
Bill
Dick Hines
Dick Hines
I don't ebonize my finials. I make all my finials out for blackwood or ebony pen blanks. Ebony works great because there is some visial grain and it does not look so much like plastic.
Pen blanks work well because there is less waste.
My problem with ebony is if it is all black, meaning no brown or other defects, then it looks incredibly plastic if you buff it up to to a gloss. It fact it looks just like dyed poplar when finished this way. I find leaving it a satin finish much nicer.
Rob Wallace
Try African Blackwood....
Rob Wallace
Richard:
I agree that ebony turns nicely, but if you like ebony, you will REALLY like African Blackwood (Dalbergia melanoxylon), which I find superior to ebony for finials, small spindles, and other items requiring fine detail. It matches or exceeds the turning characteristics of ebony without any of the brittleness that ebony has. I have had blackwood pieces that could be shear scraped to a finished surface that did not require sanding. It threads wonderfully, and retains a 'woody' character while being very dark or entirely black. I much prefer blackwood to ebony.
Rob Wallace
Bill Howatt
I agree and I love turning blackwood but it is good to have a method in the toolkit that allows you to use some less expensive wood for a large black piece or whatever reason.
Bill
Steven Antonucci
Bet a lot of folks couldn't "spot the real one"
steven antonucci
If you look at all of the various ways that one can add a black component to a turning, it's pretty wild. I would bet that most turners couldn't pick the real ebony finials from a line-up. I know I'd have trouble.
S
Steve Kubien
Steve Kubien
I use India Ink on my finials followed by rattle can lacquer or a friction polish.
I will NOT use African blackwood because it is so hideously endangered. Ya, a finial is only a tiny piece of wood but for every tiny piece we buy, the supplier has to restock so..... Same goes for a lot of variations of ebony. Won't touch the stuff.
Jim Evans
Jim Evans
Thanks for all of the comments folks.
I have some Higgins eternal ink that I will try. Also, I think I'm going to try a single coat of gloss black lacquer with a couple of clear coats on top just to see what it looks like.
Gary Asbury
Folks, If you have access to paint stores that carry Mohawk products, they have dyes in both quarts and gallons. They are acetone based and dry instantly. We use them in our shop spray booth constantly and do alot of black, and black over other colors. Alot easier than ink, etc.
