Could I Beale Buff a headlight? OT
The headlights on my Mazda Pickup are cloudy or sort of frosted looking. I know there are products you can buy to buff them with, but I wonder if I could Beale Buff them? Any Thoughts?
Re: Could I Beale Buff a headlight? OT
Mike Brazeau
One of our guild members has done his face shield and said it did a fantastic job. He did the normal tripoli, diamond paste etc.
Re: Could I Beale Buff a headlight? OT *LINK*
Mike Stafford
I am sure it can be done if you have the right compounds and wheels.
I buffed some plastic a while back and used a string buff that I got from Caswell Plating which is one of the most comprehensive warehouses for buffing compounds, wheels and machinery.
Here is the link:
Buffing wheel for plastics
Jim in River Oaks, Ont.
Ditto on Caswell, I use their compounds on my pens,
take care,
Jim
I did a Saturday demo in a neighbor's.....
JamieDonaldson
..driveway last summer about how to hand buff fogged plastic lenses. We worked on 4 cars that day, using rubbing and buffing compounds and NuFinish car polish to top it off. With the cost of replacement housings these days it's definitely worth an attempt at polishing!
Matt Birchfield
That's one of the things my company does... just wet sand with progressively finer grits up to 1000, maybe 2000... it's way faster than buffing. Use a random orbit sander if you have one. The problem is that you remove the UV coating. I replace it with automotive clear coat. If you don't re-coat the lens you'll need to repeat the process again relatively quickly. Even without the UV protection you'll see better at night.
Re: I did a Saturday demo in a neighbor's.....
Jim Sebring
Take a look at Don Pencil's PL buffing stuff. It's designed for plastic and lacquer (PL). www.donpencil.com .
Mark
I found a kit, from one of the big red box stores that is made for polishing headlights. It's made to be left on the car and polished right there. Don't know how it works yet as I am in Wisconsin and in the middle of six months of Death's icy grip. I think it's made by a rather large company.
Hope this helps
Mark
Try
D. Hansen
Micro-Mesh they make a kit to do just that.
Re: Try
Peter Lamb
Mother,s sells a kit 'Powerball 4lights" which includes a spherical cotton buffer for use in an electric drill, liquid buffing compound and four grits on two pads for sanding. It is designed for use with the lens on the vehicle.
A bit pricey but works well
Faceshield
Bill Howatt
It is necessary to have a light touch and not overdo it. If you buff too long in one place you can remove more plastic and create a lens resulting in distortion.
Bill
Harbor Freight has a $10 kit
Al in NJ
http://www.harborfreight.com/12-minute-headlamp-lens-restorer-kit-65938.html
BArry I just bought Headlight restorer from Auto Zone. It was quite simple and took me about 15 minutes per headlight.
Jim Rutten
I would think it would be tough to pick up the truck let alone turn it under the buffing wheel.
Or carry the lathe spindle mounted.....
JamieDonaldson
...buffing wheel out to the truck?
