Spent the evening in Nashville at the start of the Symposium. Of course it actually starts to day but I needed to take so lighting down for them. I've already met a couple of new friends. Looking forward to getting there this morning. It's about an hour drive so I better get my shower and hit the road.
I talked to Doug Thompson last night. He said he has improved his tools with a new Heat treating guy. the hardness is now 62 to 64 so the edge should last even longer. Can't wait to try one out.
Talked to Bill Grumbine for a few seconds, I was running setting up gear. I hope to get to sit down with him later. Same is true with Molly Winton and Micheal Mocho. Didn't see Stewart Batty yet but will look him up also. Talked to Lyle Jamieson for a second but like me he was unpacking also.
Probably the best thing about these events is getting so see turning friends that you only see once or twice a year. Wish I had time to really sit down with them but end up running here and there.
I'll send a report on the Elephant lathe. They were setting it up last night. It's an impressive machine.
This is the 3rd time I've seen Stewart Batty. He is so full of information you have to learn something even if you've seen the same demo. It's just impossible to remember it all.
Micheal Mocho is just plain good. Funny, entertaining and full of information. The best tip was to use Dawn dishwashing liquid as a lubricant to make the threads cleaner when hand chasing. Can't wait to give that a try.
Bill Grumbine is both funny and full of good turning techniques. Enjoyed his demo.
Now If I can just get a chance to see Molly Winton.
Of course the best part is just meeting other Woodcentral people. I've met 3 or 4 who lurk and few who post. I've had some good conversations with other turners and picked up some tips.
I do not know much about patents but patent pending???? There is not a thing original on that lathe that I can see. Wish the gentleman well but the tool rest looks exactly like my home made one of 15 years ago. The tail stock well I think my home made one looked better.
Can one really patent a shaft with two bearings and a motor?
Not sure if the price point is in the right spot. I would thing 2k - 3k with the motor.
Steven Actually there are several things original on this lathe or at least some of the modifications they showed me. On one model you could actually crank the bed forward or back to give you a short bed or long bed. One was able to change the swing by lowering the bed. Of course you could also completely remove the bed or add more bed extensions. It seems like a very versatile lathe.
..design features at the last 2 AAW Symposiums, but not with that name? That's a very small footprint to support the size of the turnings used in their ads. Unless it was welded to a big steel plate, or otherwise securely attached to a reinforced concrete pad, I certainly would not attempt the size turnings illustrated!
