Using a 1/4" Bench Chisel as a Bedan *LINK*
charlie belden
I use a 1/2" curved edge skew and a 1/4" bench chisel as well as a 1/16" shop make parting tool for all sorts of turning - and probably not like they're supposed to be used. But I get them to do what I want them to do - most of the time.
So - for those who have avoided using a skew and bedan, or don't want to plonk down a chunk of change for a
REAL bedan - a quarter inch bench chisel may act as a gateway experience to the bedan and skew. I did a quick video of a few of the ways I used an inexpensive regular old bench chisel - that would be difficult to describe with just words - or even some still photos.
Have a look and see if the vid gives you enough of the idea of how to use a bedan.bench chisel to make some common cuts usually done with a spindle gouge. And if you have questions feel free to ask away.
Using a bench chisel as a bedan
Re: Using a 1/4" Bench Chisel as a Bedan *LINK*
Andrew LaPorte
video problems ????
Emmett Manley, Lakeland, TN
Who needs a Bedan tool when a Belden tool is just as good? I use a small regular chisel often and I wondered if I was the only person who did so. Interesting, thanks.
Leo Cuellar
Leo Cuellar
Thank you for demonstrating the technique, Charlie. I was looking at one of my 1/4" sash chisels the other day and wondering if I should try it. I've got 5 different skews I've been practicing with the past few days and it is starting to pay off now. I still get a catch now & then but its not a big deal any more. Trying to get a clean surface on that hemlock is improving my sharpening skill as well.
Chuck Engstrom
Good suggestion, Charlie. Enco sells 5/16" square high speed steel tool bits in 6" or 8" lengths that you can grind to the appropriate shape. An 8" is $6.91, hard to beat. (Link below). They also have 8" lengths in 1/4", 3/8", and 1/2" but 5/16 is my favorite all-around.
I've made several of these, in various sizes, over the years and use them almost daily. I grind them to right around 45� angle with the edge in the center, which I find to be about right for cutting well but not too aggressive. Sorby and Taylor make square parting tools but they're 'way more than $7.
Best to all--
Chuck
Enco 5/16 x 8" square HSS bit
john lopez
The Sorby Bedan Tool has sides that slope inward at the bottom allowing for clearance, so the tool doesn�t bind in the cut.
Later when I make one from square stock I may grind away a little if it binds.
It didn't look that hard to control but I'm curious about how it might behave
with a more standard length shop made handle.
In the meantime I have some unhandled bench chisels for a project,
I'm going to try one on my Thompson aluminum handle and get some practice
that way.
Great idea, thanks for posting.
charlie belden
. The Sorby Bedan Tool has sides that slope inward at the bottom allowing for clearance,
You can easily cut some side clearance room so binding isn't a real issue when turning a
smaller diameter cylinder between two adjacent larger diameter cylinders.
You will notice, at the beginning of the video, that the bench chisel has the sides
ground back - sort of dovetail tails shaped
If you already have a bench chisel, sash chisel or mortising chisel - why MAKE
a similar tool?
I've found no need for a longer handle - for spindle work. I also use the bench chisel
to turn into end grain - for working the fit of box lid to the box - but that doesn't
require much reach passed the tool rest. Shorter seems to be more easily manipulated
and controlable for small precise cuts
Now that I think about it, the shorter bench chisel's length discourages using the tool
for things it shouldn't do - like deeper scarping in the bottom of a box three
or four inches deep
> that way.
If you already have a quarter inch bench chisel - try it as is. Mount a 3/4" blank
about 8" long between centers and cut a bunch of beads. Then do another
blank. I think you'll find a regular length bench chisel to work fine.
john lopez
I reviewed it and saw the bevels.
a similar tool?
I see your point...
Maybe it is a stage I am going thru.
I enjoy making tools because I can but nothing beats being able to simply grab a tool in the heat of the moment and keep working.
or four inches deep
I agree, this makes sense.
> that way.
Last night I ended up playing with a short spindle and tried it both ways.
The familiarity and heft of the Thompson handle felt good in my hands but the bench chisel worked fine.
Thanks again for the tip, it's a useful one.
