Spheres
Spheres
Spheres
Paul Zerjay
Hey I need some help. I cut spheres with a skew using lathe turned wooden cups between centers. I turn a ball, mark the center, rotate 90 degrees, chase the ghost, and repeat. This should take 3 times and you should end up with a round sphere. I have one cup chucked and the other I remove the point of my live center and insert the cup, that has a tenon matching the dia. of the point, there. It's been a couple years since I turned any spheres, but I remember doing so with a lot less trouble than I'm having now. I have no wobble in the cup centers, but I still get a nipple on one side of the sphere. I know my centers line up as close to perfect as any other 3520 I've turned on. I'm rotating 5-6 times and still not coming out perfectly round. So then I thought that the wooden tenon might be getting a little sloppy inside the live center, so I switched to a threaded nut screwed onto the outside threads of the live center. Still the same. What am I missing?
Re: Spheres
Re: Spheres
Dick Wilson
Paul, You didn't mention the diameter of the sphere. I have never tried the method you are using. If your sphere is large enough ( and you get way frustrated ) you might try what I have done. If the sphere diameter is large enough you could use 1/2" rings of 2-4" pvc pipe. As you turn from the center point of the sphere turn towards the tail stock or headstock. Nibble the wood away constantly checking with the ring. If you see light, nibble more. When you move the ring from the center to the tail stock with the entire ring touching it is round. Same for other side of center. I saw it done in someone's video/read about it....can't remember. Good Luck Dick
Re: Spheres
Sound like an alignment problem......
JamieDonaldson
...with your cup centers? Have they been trued up recently, and also check the lathe headstock/tailstock centers alignment. Moving either can cause minor alignment issues.
Re: Spheres
Re: Sound like an alignment problem......
I have turned a bunch of spheres just as you describe. If you are going for a random size, do as you describe. I suggest you turn the speed up as fast as you dare and change the lightning to emphasize the "blur" and cut it away carefully.
I made a set of croquet balls. They had to be 3 5/8" +/- 1/32" IIRC. That made it interesting. Set them up as you do when you start and turned them about an 1/8" over sized. Used a parting tool to cut a groove around the equator and make it exactly 3 5/8". Then I made a piece of flat stock that fit in the groove and chuck it between the jaws of a chuck. Then turned the groove away. they were Dogwood and the people were pleased with them.
Re: Spheres
I don't know what I'm doing wrong
Paul Zerjay
I make the last rotation very carefully to insure the horizontal axis stays horizontal, and it's still giving me fits. I gotta be doing something wrong, but I can't seem to figure it out.
I've tried the parting tool trick before to get an exact dia., but these are just random, so theres no need.
It'll come to me. I was just hoping someone here might notice a step I'm forgetting, or see something I'm missing.
Re: Spheres
Re: Spheres
Doc Green
Paul, any chance you're cutting too deep into the ghost? That would do it.
Re: Spheres
Re: I don't know what I'm doing wrong
Paul I had the same problem. I found out my homemade tailstock cone was simply not large enough to align the ball properly. I made another one that was twice as large and the problem went away.
Re: Spheres
PS...
I have been thinking about this and remember having a similar problem. As I recall, I got to casual about it and found that it was important that the first time you turn it you need to get the center part pretty close to an actual Sphere. Might be good to make a paper or cardboard pattern and use it to be sure the part the tail cone will rest on is a section of an actual sphere. and try to be careful to re-orient close to ninety degrees.
Not sure its necessary to make the cones larger, but it might help.
Re: Spheres
John I think you're onto something
Paul Zerjay
I had the same thought last night while sleeping on it. My problem I believe is my cup center on the headstock end. I always try to push the envelope and a smaller cup center allows more material to be worked on the sphere itself.
I am switching things up this year and turning more bowls than I normally do. The spheres will be a nice visual when placed in a bowl for sale. Artsy stuff gets you into the show, but hasn't been selling terribly well the last couple of years. I'm going to the more utilitarian approach this year. Pepper mills, bowls, and,dare I say it...? Hand mirrors?
Re: Spheres
Re: John I think you're onto something
Doug Wolf
Paul,
I had the same problem. Every time I rotated the piece, it could be moved sideways a fraction of an inch in the chuck. The cone, or diameter, of the concave was larger than my ball. The ball would make contact with the center of the cone chuck, not the rim. So it wouldn't "self center" itself. The smaller you turn the ball the worse it gets.
Hope this helps.
Re: Spheres
Re: Spheres
Fred
Hello Paul,
I've turned hundreds of spheres (balls) over the years. I normally use a swinging jig if they are under five inches in diameter. Over 5 inches, I have to switch to freehand. If you will e-mail me, I'll send you the article that is in the February 2011 issue of More Woodturning on Turning Six Inch Balls.
