Carving uphill out of a hole
Keith Newton----Little Rock, Arkansas
I am currently working on a turning, which has a bird in flight, with wings down in the bottom of the stroke, with a large egg vessel inside. The space under the wings, and above the egg, will act as handles.
I started by drilling three holes, then sawing between them, but there is a lot of carving to get worked out under there, in a space about 3" X 3" X 3/4". Of course, it is against the grain carving from outside in, and is one of those situations where no matter how many tools you own, you find you need a few more.
However, to start with, before I even got out the carving tools, I picked up my bowl gouge, with the swept back side grind, and found it to be quite handy at inserting in the drilled hole, then levering back while pulling out, gives a nice shearing cut with a lot of power behind it.
This lead me to alter the sharpening of a spoon gouge as well. It had a slight finger-nail curve across the end, but bringing the sides back a bit more allows for a bit of shearing on the sides as it is rocked around on the way up and out.
Green Catalpa is nice to carve, other than the smell.
