A Different Take On Multi-Center Turning
charlie belden
I realize that there's very little new under the sun. So this has probably been done by many other turners. But it's a New To Me idea to try since multi-axis turning is interesting - at least to me.
It seemed obvious to me that turning between corners of a square blank - two sides being side grain and to sides being end grain - would probably involve dodging flying wood. But if I turned on the diagonal I'd have a compromise - and hopefully enough structural integrity to avoid injury while turning.
Here's the idea
Mount between centers and turn the mitered corners round and turn an arc between adjacent corners. The center of the arc will be almost square to the top and bottom, the arc becoming more and more round as it approaches each "corner"
So far so good.
Have no idea where this will go - if it goes anywhere at all - but it's been interesting so far.
Anyone tried this or seen any pieces that use this Diagonals Idea? Might work better starting with a cube - but I had this piecee of a poplar board to play with . . .
Re: A Different Take On Multi-Center Turning
Katherine Kowalski
Katherine Kowalski
Giulio Marcologo does a wonderful demonstration making a three-cornered bowl using exactly this technique. He mounts a cube of wood, and cuts on the diagonal.
Makes a very interesting finished piece!
Katherine
Link to photos of his piece(s)
charlie belden
Katherine Kowalski
Re: Link to photos of his piece(s)
Katherine Kowalski
Charlie,
Did a quick search on the Internet, but I don't know if he has a web site. I saw his demonstration of the three-corner bowl in Utah a couple years ago.
I did take notes, but don't have any photos.
Katherine
Bill Noce in Northeast Ohio
Charlie Mark Stleger does a box that he calls rock a bye box its a 3 corner box. Check his handouts...... www.markstleger.com
Leo Cuellar
Re: A Different Take On Multi-Center Turning *LINK*
Leo Cuellar
Charlie, Charlie, Charlie! I've been dabbling with a not dissimilar concept. No doubt in working with that form you've also discovered a rather novel way to beat the heat when summer rolls 'round again. I like the way the shavings swirl all over the place, kind of like one of those hurricane money booths from a game show :D
Working on a battle axe form. Still refining my drawing of the carving I intend to do in the center portion, a modified celtic cross. Also the reason I was playing with reactive metallic paint. I want to make it old looking. I haven't yet decided whether to go Bronze Age or Iron Age. I found the recent thread on sandblasting most timely & informative.
Done with a narrower piece of wood you could simulate a felling axe.
My first stab at it done just after Christmas...
using the assymetry
Charlie- this reminds me of the work by....
JamieDonaldson
... a very interesting Canadian turner named Peter Rand. I have added a box of his from my collection, and he has done many variations of what he defines as "femispheres."
Re: Charlie- this reminds me of the work by....
charlie belden
I've seen photos of some of Stleger's 3 triangular boxes though I didn't know he did rocking versions.
Leo:
I look foreward to seeing your Bronze Age Battle Axe.
Your Three Legged, five axis, piece looks scary as hell to turn - but there is that Cooling Fan effect that could be appealing - during hot weather. Alas, I live in the San Francisco Bay Area and we are "cursed" with moderated temperatures - 45-85 F, with maybe a week of high 90s to very low 100s, seldom on consecutive days.
I'm familiar with Peter Rand's femisphere. We've been exchanging e-mail about kinetic and dynamic pieces. He was the one who turned me on to incorporating micro-controllers in pieces. He uses actual movement aesthetically - whereas I use it more like a circus act.
With all the possibilities that multi-axis turning has it's surprising that it isn't used much. Multi-axis turning doesn't provide instant visual feedback of the form as you go like single axis, full round cross sections does. That may be one explanation for why more multi-axis turnings don't show up in turning forums. It really is an interesting area to explore - and not nearly as intimidating as it first seems.
Leo Cuellar
Leo Cuellar
Charlie, I had no problems with the piece wanting to fly apart even with a few serious catches. I used a 1/2" Steb center to drive it with, so any time this happened it just stopped the piece without any damage. The hard part is working close to the tailstock to get the reverse arc. I don't have one yet, but it occurs to me that one of those curved Hunter carbide hollowing tools might be a good choice for doing this. I believe I had to reposition my tool rest behind the tailstock to get the clearance I needed. It really wasn't any scarier than any other winged piece I've done. It was a good solid piece of maple, not sure I'd try it with spalted wood.
Re:femispheres
Ray Carson - Lawrenceville, NJ
That's WILD !!! I like it.
Re: Charlie- this reminds me of the work by.... *LINK*
fgvanatta
Peter Rand's "Femispheres" are indeed interesting, but these boxes are not multi-axis turnings, but rather simple symmetrical turnings that are split, rotated, and glued back together. Also see Hans Weissflog's "Drunken Box" series.
For those curious as to how Femispheres are done, see the link below.
Turn a Femisphere
Peter Rand's femispheres are not glued,.....
JamieDonaldson
...but held together off axis by well hidden magnets.
Re: Peter Rand's femispheres are not glued,.....
fgvanatta
True. I was just referring to the "how to" PDF that shows the general method for making a Femisphere. Thanks for pointing that out.
Frank
Re: femispheres
Bruce Pratt
Take a look at Wood Turning Full Circle by David Springett ISBN - 978-1565234062. A whole book full of these kinds of turnings and more.
- No connection with author or publisher; just have the book.
