Re: I'm quite surprised that the bearing.....
Bruce Smith
Not sure what type oil is required but like someone else suggested light machine oil would probably fill the requirements. As far as oil seals they should not be to difficult to obtain. Try you local seal and or bearing business, they sometimes are a division of a power transmission shop. Measure the outside diameter of the headstock seal bore and also the outside diameter of the shaft the seal runs on and purchase a seal that fits these dimensions. If you don't have a vernier caliper or similar measuring device, dismantle the head stock and take both the housing and the shaft to the shop and have them measure it you should ask for a double lip seal. They no doubt will be able to fill your requirements. Good Luck
