Shrinking wood and instant gratification
Mike Foster
Sort of a follow up to my post and John's. I finished turning the frozen wood that I started Friday by hollowing it and turning to thickness yesterday. It is sort of a hollow tube type form, hollowed from both ends and turned to a wall thickness between 1/16 and 3/32 for piercing later. I had it last chucked up with some cole jaws and duct tape for insurance (also used a large steady around the piece for stability). I finished turning it, and the wood was still a bit too wet to sand so I just left it on the lathe in the cole jaws and steady to try to control warping as it dried. Went out to the shop today to get the frozen compressor up and running (which is in an unheated shed under the shop). I decided to check on the piece and much to my surprise it had shrunk from 10" in diameter to 9.5" over night at the widest point, and about half that where the form was about half the diameter. It shrank pretty symmetrically, as I had wanted. I thought it would because I started with a whole log pretty much centered on the pith. No pith in the piece now, so no fear of cracking.
I was surprised that it had shrunk so much over night and that it was ready to sand, which I did. It is now done and off the lathe.
I normally twice turn, and have tried most of the methods for controlled drying. I usually have enough rough pieces hanging around to keep me busy. Turning wet and thin, avoids all that, but you have to expect the wood will move, and plan your piece around it
