Jet Bandsaw HELP
Jet Bandsaw HELP
Jet Bandsaw  HELP
James Pittman
I have a 14" jet bandsaw that has very little run time on it about 10 hrs. but it is 4 yrs. old . it worked find until about 3 weeks ago. I try to cut some wood and it would come on it just hummed I cut it off and turned it back on a twice and it started up and work alright till today.I try today to cut something and it would not start just hummed . I spunned the top wheel and would start up. took belt off motor but the motor still would not start on it own. 1hp 115 volt motor but can be wired 220 volt HELP can anybody give a idea what is wrong. Thanks Jim
Re: Jet Bandsaw HELP
Wayne Kuhn
Get anew capacitor-Classic signs of a bad start cap.
I am pretty sure Wayne is exactly right, Capacitors can fail from age whether they are used or not, but you might try blowing out the motor on the off chance it has a centrifugal start switch that has gotten dust in it.
Bill Turpin in WNC mountains
Start caps go bad because they stay energised for too long. They are supposed to be in the circuit for less than a second. Too long on and the salt solution inside boils and causes internal shorts. The centrifugal switch takes them out of the circuit when the motor gets to ~75% of full speed. Burnt or stuck switch contacts, bad bearings in motor or saw, too much load on the blade, too tight guide blocks, etc can cause slow starting. If you have a bad cap, find the cause, or failure will quickly repeat! The brown wax plug between the caps contacts will be missing or cracked usually if bad. Good caps can carry a NASTY charge that will be discharged by your fingers. Be careful. :(
Don't buy the capacitor from Jet
Dick Coers
Get it from Grainger, or other motor supplier. It will be a fraction of the cost from Jet.
James Pittman
After reading Barry's advice I blew out the motor with my air hose and now it start every time. I will remember all your advice so I will know were to start if it happens again. Thank you all my GOD bless you Jim
john lopez
This thread is another great example of how helpful this web group is.
Nice work gentlemen.
