Caliper (divider) alternative
Doc Green
Here's what I do to avoid having to get the sharp points of a divider near a piece that's spinning on the lathe. (See Survey below.)
First I set the desired diameter on a dial or digital caliper. You could use a divider. Then, usually with the lathe off, I position the caliper against the workpiece so that each jaw is the same distance from the center, by eye. I mark the location of the left jaw, take the caliper away, and then position the point of a pencil where I made the mark.
Turn the lathe ON, and make a circle on the workpiece. Check the diameter of the resulting circle with the caliper, and then make another circle either larger or smaller than the first, as required. Check it again, repeat, etc.
With two circles, I can usually get within 1/16" on the diameter. Seldom do I require greater accuracy. And all the while, the sharp, steel points of the divider (which scare me) are hanging on the wall behind me.
I can do this quickly. What worries me about using the divider is that I might bobble and accidentally touch the right-hand point of the divider to the workpiece, or screw up somehow and have the divider get tangled up in the wood, which might bend the divider. ~Doc
