Sandblasting equipment
Steven Antonucci
steven antonucci
So for those of you out there with intermittent requirements to sandblast your work, what equipment do you recommend? I have a compressor, and I plan to build a small cabinet out of some scrap plywood. Do you still need a respirator if everything is in an enclosed space?
S
Re: Sandblasting equipment
Ken Ward
Yes you definately should where a respirator,as all that grit is going in your lungs.i have no idea how big your compressor,but it should be able to hold at least 90lb psi.I used to sandblast heavy equip and had a full body suit,with a full head cover and respirator.What to you plan on blasting?If you blast certain metals,you have to be carefull in what type sand you use as reg old rough grit sand can ruin some metals.i have a small cabinet now that I use to clean PO box doors and all I use for them is play sand from any home cent as it works great and is about 1/4 cheaper than sandblasting sand.
Bill Howatt
I only have done a little blasting but I definitely wear a respirator. Stone dust, glass dust etc are a bigger lung hazard than wood dust. Of course, if you can guarantee that no ultra-fine dust is escaping then OK but that probably means the lid is going to blow off your container too.
I bought a hood that covers my head and neck with a plastic window in it that I wear over the respirator. Keeps the dust out of your hair and down you collar. You can wear regular coveralls or clothing but use something without buttons such as a sweatshirt. You can put some masking tape around the wrists.
Are you trying to accent hard and soft grain lines in turnings? I haven't tried it yet.
Bill
Steven Antonucci
More info
steven antonucci
I plan to sandblast wood, intermittently.
I have an option of doing it in an enclosed cabinet or outside. If the cabinet didn't require all of the OSHA stuff, I'd go that way. If it does, I'm probably just going to go the hood route with a respirator.
Any better?
S
Re: More info
Joe Dickason
We use glass & plastic beads at works to clean rubber molds. We use a similiar cabinet (only much larger) as the Harbor Freight attached. I'm not a huge HF guy, but for limited use item sometimes you can't beat the price ($119+/-) or build much. This might eliminate the need for the respirator.
http://www.harborfreight.com/abrasive-blast-cabinet-42202.html
Terry Scott
Steve
I brought a cabinet and have set up a vacum to get rid of the dust
However the cabinet cab be restrictive as the larger pieces I make wont fit so I do out side with hood and mask
The next issue is the size of the compressor you need .Beware that a compressor usually states the cubic capacity dont be fulled by this
I brought the largest single phase I could On the thank it has 18cfm yet the free air at 100 psi is 11 .The sandblaster works for about 2 mins then the compressor struggles to keep up running continuously
To sand blast wood is a slow process and experimentation with grits is recommended
The worst thing for air usage is the small die grinder.
Randy
Look into soda blasting, less invasive but works the same. Use power washer to push the soda. Can blast paint off wood and not harm the wood surface.
How do you feed the soda into a power washer?
mjonesrdg
Re: How do you feed the soda into a power washer?
Randy
It is baking soda and is sucked by a venturi tube from a bucket. Comes out the end of gun.
Re: More info
charlie belden
An enclosed cabinet can be used INSIDE - where it's dry and maybe warm. Wet sand and wet wood don't make for sandblasting off wood.
Things to look for in a cabinet sandblaster
1. a decent light inside so you can see what you're doing
(a fluorescent tube inside a replacable glass or plastic tube,with
rubber caps on the ends is handy. Switch should be outside
the cabinet - preferably on top rather than on the side. Sand
will get through even tiny gaps)
2. side opening access door. Top opening access doors tend
to get "sand" all the way AROUND the sealig gasket where
it sits there. If you blow off the seal - you blow stuff into
the air - and then into your lungs - that you don't want
there.
3. sealing gaskets made of closed cell foam get smushed and
collect fine grit that often can't be gotten off, even by
trying to blow them off with compressed air. "O" rings
out of harder rubber or synthetic make better seals and
are easier to get grit off of.
4. even a glass window will get cloudy due to abrassion. 1/4"
plex is easier to replace. Glass or plastic, cover it with a
replacable, sacrificial sheet of thin plastic - taped all the
way round. When it starts getting semi-opaque, replace
it.
5. these things need a LOT of air - 8 CFM minimum. You'll
need a larger compressor toprovide the needed CFM
and PSI. The larger the tank the bigger the air resevoir
and the less time the pump has to stay running. You
DO NOT want the pump running continuosly so forget
the portable little twin-tank units. Look for 30 gallon
tank at a minimum, 50 even better. And skip the
buzzing diaphram compressors and go with a cast
iron oil pump - with inline filter.
6. WEAR A FULL HEAD Positive Pressure RESPIRATOR.
There will be very fine dust - and if you're using sand
which is silica - and you don't want it in your eyes or lungs.
The larger the nozzle, the more area covered - but
more air flow is needed. The smaller blasting "pens"
won't work as quickly, but require less CFM - and give
you more control.
Tip: If you want to mask off areas from being sand
blasted, get the surface smooth and sealed - with shellac
or sanding sealer. Then paint on rubber cement - that
you've let some of the solvent evaporate out of to make
it thicker. Peals off easily when you want to remove it.
You can get "rubber frisket"- that's already thicker
- and is PINK so you can see where it is.
Sand blasting works well with open grained and softer
woods. Not so good on harder woods - espcially the
"exotics".
Bill Neddow
Very good advice, Bill.
