Cold hands and feet
Cold hands and feet
Cold hands and feet
Mike Foster
I just got in from the shop, roughing out a new piece. I had a bit of a log that was left by tree trimmers that work for the power company. I originally thought this was ash from the bark. Turns out it is red maple. It has been cold here in VT for quite some time. Varying degrees below freezing, but usually not warmer than that. The log was frozen when the tree was felled, and has remained in my barn under the shop where there is no heat. Frozen solid. Had to give it a go just to see how it turns. I would say that it turns just about as sweetly as if it was freshly felled and not frozen. My shop is heated, but turning that frozen wood got my gouge, hands and feet (from the piles of shavings on the floor) pretty cold. I don't use gloves when turning (I know there a is wide variety of opinion on that) and I noticed that the wood coming off the gouge was a bit harder on my hands than normal, more like little chunks of ice hitting them. I got nice streamers of wood flying off the piece, but the shavings seemed to shatter, so the wood was more like coarse sawdust than long shavings. That was interesting. Nice part is that you and the the shop don't get soaked.
Re: Cold hands and feet
Walt Bennett
Interesting -thanks for sharing!
Walt Bennett
Very interesting Mike. I've read about people turning fragile wood by freezing. Well you can have it. I prefer to be turning where Kelly Dunn is, Hawaii. I can only stay in my shop about 3 or 4 hours before my feet and hands get tool cold. It just saps my strength. My shop is heated but not adequately. For the last 3 weeks I don't believe I've gotten it over 58 degrees and usually hovers around 48 to 52. It costs $80 to fill up the propane tank and I don't get much use out of it. My son and I are building a set of shelves. The wood cost $100. Heating the shop so he can paint has cost me $160. I've got to somehow improve on that. I have a wood stove left over from my previous house but the insurance company won't let me run it.
Come on Spring. I need a break. :)
Barry L Elder
Veeerrrrrrryyyyy interesting!!!! Your story really stimulates my warm sunny imagination! :D
Bill Neddow
I have had pretty much my experience, Mike. I liked turning Black Walnut this way as it seemed to tone down the nasty dust and chemicals that make you cough. I also learned to wear a skin-tight fingerless glove on my left hand to counteract the effect of the shavings piling up on the back of my hand.
Bill, from up in in Canada.
Insulation
Doc Green
It's the gift that keeps on giving, both in winter and summer. Every little bit helps, but to get the full benefit you have to do it completely. That is, find every heat leak and fix it. ~Doc
Leo Cuellar
Leo Cuellar
What Doc said. I haven't completely finished insulating the shop yet, but what I've done so far has helped a lot. I will probably add some propane heat when done so I can do some finishing during the cold months, without it costing me an arm & leg.
Many years ago I bought a foot warmer.....
JamieDonaldson
...pad for Shan's desk- at that time our office was tile on a concrete floor. It's made of heavy rubber with a 110v heating element embedded, and works wonders now in front of a lathe during winter. Just keeping your feet warm makes the rest of the body think you're warm!. I have no recollection where I found it, might have been in an office supply source, but it works well for me. :D
Mike Stafford
Re: Many years ago I bought a foot warmer.....  *LINK*
Mike Stafford
I do not tolerate cold at all and when the temperature is below 45 or so I don't bother with the shop. I have a slab floor and when I built the shop I did not insulate so it is like ice in the winter. My feet get cold and I am miserable.
A friend had some hog warming mats that were in good shape and offered them to me to try. They worked but they are built from a rigid plastic and were uncomfortable to stand upon.
A company called Cozy Winters offers heated/padded floor mats. They are not cheap but they do work.
Here is the link...
Cozy Winters
That large foot warmer appears to be......
JamieDonaldson
... exactly what I have Mike-thanks! I've always wondered how much current it draws, and now I know. The important thing is to remember to unplug it when not in use.
Re: That large foot warmer appears to be......
Lan Brady
I second the Cozy Winter Mat.
I have mine switched into the light, so it is one less thing to remember!
Lan
John Leonard
Jamie, what is the physical size of the mat? Thanks John L.
Brad Vietje
Brad Vietje
Hi Mike,
Glad to hear you're getting to do some turning! I've turned a lot of frozen wood, but usually in an un-heated barn or garage, which is not fun. As I age, I'm less and less tolerant of such conditions, but I still think turning frozen wood works well for softer and stringier woods, and sometimes spalted wood and delicate or thick bark, like Walnut. I expect by next winter I'll be able to turn frozen wood in a heated shop -- fingers and toes are crossed -- or is that a cramp coming on?!?
I'd strongly recommend hot coco or tea or hot buttered rum for the next few days and getting your turning fix from videos or books. Up here, we're looking at -22 to -30 tonight with a high around zero on Monday... I'm staying inside!
Safe spinning,
Brad Vietje
Newbury, VT
Barbara Gill
It is rare that my feet get cold but when the temperature really drops I will put one of those chemical earners for feet between my socks and shoes. I also can slip one in my gloves next to my palm. They really do the job.
sizes
Specs:
* Dimensions:
Regular: 20.5" x 13.75" x 0.25"
Large: 36" x 16" x 0.25"
* Electrical:
Regular: 115 VAC, 85 watts, 0.7 amps
Large: 115 VAC, 135 watts, 1.2 amps
Mike Stafford
If you need a larger heated floor mat... *LINK*
Mike Stafford
and significantly more expensive try the link that follows. Since these mats are designed for continuous outdoor exposure I would imagine they would last a while inside the shop.
Heated outdoor mats
Re: If you need a larger heated floor mat...
Wayne Kuhn
Hmm... $3000.00 I would not have to shovel snow again. Warrants some thought.
24'x24' and just heat the whole shop:)
