Instant turning gratification
This should be a fun topic. At least a couple of times a week on different forums the topic comes up of how to dry a bowl quickly. I know I've gone through this. We (or at least I) have a sort of want to have it now attitude. Based on what I read so do most turners.
My thoughts are, how do you as a turner get around this desire?
I rough turn bowls and put them up to dry. Then after I rough turn several I stop and finish turn one. It could be a green one from that same log or it could be a dry one from the stash. This gives me the satisfaction of having something to show off while still putting green ones up to dry. I don't have to wait 6 months because I already have a backlog.
Before I started doing this I turned mostly things like my hand mirrors, boxes, and Christmas ornaments that give the instant gratification. I still do that between green pieces simply because I have trouble waiting like anyone else does.
I don't want to take the time, expense, or mess of doing things like Alcohol soak, Cedarcide dip, soap dunking, boiling, or microwaving. I do microwave on occasion. Sometimes you just gotta have something right now.
Re: Instant turning gratification
Brad Vietje
Brad Vietje
I'm with you, John.
I haven't turned much lately, but when I rough out bowls, vases, hollow forms or boxes, I tend to make quite a few. Over a short time I accumulate quite a stash, some as much as 5 years old, so I can have access to dry wood whenever I want to finish a project. With hollow forms and natural edge bowls, I often green turn to completion, so if the walls are thin enough I can still get a finished piece fairly quickly, though not quite immediate.
Hoping to turn a lot more when the new house is finished. Seems like we have 1" to go, which roughly translates into 5 weeks and $20K!
Safe spinning,
Brad Vietje
Newbury, VT
Bill Howatt
I turn as a fun hobby so I have no sales pressure.
When I started turning a turner told me about turning green then waiting for several months before doing the finished bowl. I thought what a dumb scheme that is. It wasn't too long before I had enough of a dried bowl backlog that I didn't really care. I always look at a green log and just know and accept that it is going to have to dry.
I turn ornaments, jewellry, etc. from purchased, dry exotics as well, and to be honest, I'm kind of tired of doing a lot of bowls and find the other stuff to be quite rewarding.
I think it is important to mention that turning isn't my only hobby so finding time for everything is really the bigger problem and this alleviates the "waiting to dry" issue as well.
Bill
Richard Allen
Richard Allen
I don't turn a lot of green wood. I seam to prefer working with dry wood. The instant gratification things tends not to be an issue as I am usually cutting and glueing and waiting for glue to dry and coloring wood and...
I do rough green wood. Just not my primary source of turning wood. The process of roughing is a little bit of it's own reward and partly a pain in clean up. I don't much think about holding a finished product when I turn green wood. I have loads of bowls to hold.
Steve Kubien
Steve Kubien
Hmmm... I do dry a few pieces slowly over a few months but lately I have been using my fridge kiln. Like many, I don't have a lot of room so I "need" a way to go from green to dried-rough-out fairly quickly. Waiting 6 months or a year is not a good option for me. Since running the kiln I have not run out of dried rough-outs and there always seems to be another wet log finding its way to my shop.
Barbara Gill
When I first started turning I was in a hurry for the roughed out bowls to dry so I built a bowl kiln from a commercial freezer. That fell into disuse quickly. For the most part I have enough stuff dry and drying that quick is not an issue.
For those rare times when quick is needed I use the denatured alcohol soak which has consistently given me excellent results.
It comes with time and age...
mjonesrdg
Time and age, I think, has simply got me to the point where it is all gratifying. Roughing, sanding, planning,...it dosen't matter. A day in the shop makes my day complete.
Besides the patience thing, I still have a lot of other discplines to work on. My biggest failing is knowing when to quit and shut down the shop. Getting fatigued is an insidious condition and it makes me want to cut corners,(which then requires too many 'do-overs' the next morning!) and also, makes me succomb to the old "big chair" after ( which then cause me to miss too many of my Giants games!).
I may never get into a good habit of cleaning-up after myself and putting the shop "right". I wish I had a "shop boy" like my father had.
Re: It comes with time and age...
bill Crommett
It is all instance gratification now. It is too cold out in the garage, so I don't turn as much as I wish, but with the big stash of wood under the cover, all my wood is now dry, so there is no waiting.
Steven Antonucci
DNA soaking fan until I drove over the 5 Gal pail
steven antonucci
DNA used to be my go to method, and it worked great. Then, I backed the truck into the bucket and cracked it...losing 3-4 gallons before I could save what was below the crack. If I have something I absolutely need to get dry, I use it, but it has to be small.
Like John, I turn in bulk, wax and lose a bunch. They still burn.
Steve
Two Problems with waiting
Jack Savona
I have two personal problems with waiting for bowls to dry by themselves, without assistance.
First, when I finish turn a roughed-out bowl from one to three years ago, I sometimes find myself dissatisfied with its shape, proportions, and/or design. The more I learn and see, the more my bowls have undergone subtle changes. For example, I used to turn to get the biggest bowl out of the wood I had. The wood dictated the shape. Now I've learned to dictate the shape and design.
Second, there are some bowls that excited me when I roughed them out. But, sometimes it's difficult to re-generate that same enthusiasm now for an idea I had a year ago.
Lately, I've been finish turning all my bowls and kiln drying those I can't microwave. I've got a microwave in the shop near the lathe, so when I sharpen, I run another bowl through a cycle.
This method provides me some near-instant gratification. And since I do a lot of NE bowls, warpage doesn't matter. And as far as traditional bowls, I've come to enjoy the 'natural and handmade' look of the finished product.
Oh Man, you are lucky,
Keith Newton----Little Rock, Arkansas
That something didn't ignite the fumes from that spill.
I have wondered about those of you who use this method have given much thought about the fire hazard?
I would imagine that if you have insurance, and burn your own shop from an accident like this, if your insurance company didn't want to pay, and the fire inspector found evidence of a lot of spilled flammable liquid, would you get a favorable settlement?
I don't even like to take the lid all the way off of the container. While I buy thinners by the gallon, I usually refill smaller containers. When I use out of the smaller can, I just loosen the top, tilt and squeeze into a cloth. If I knocked the can over with the lid off and spilled, a compressor starting nearby is all it would take. but with slightly loose cap, a small spill would be a lot safer.
Re: Two Problems with waiting
Jack I also have trouble getting back to bowls that have been sitting. There is an initial excitement about a bowl but once it's been sitting for a while it's hard to get back to it. It is getting easier now because I look at them as raw stock and will grab one more often than I used to.
I think my biggest problem is I'm into art, not just bowl making. So It's hard to grab a rough turned blank and just make a bowl.
Peter Hyde
Maybe the ideal solution?
Thin dries quicker than thick.
Thin also warps and that is not always a desired thing.
So buy yourself a good moisture meter.
Decide on the shape and how best to exploit the characteristics of the wood and rough turn to 10% of diameter wall thickness and a good surface finish from the tool. Check the MC and write it on the bottom in pencil. Measure the diameter in at least 2 places and write that on the bottom also. Seal the bowl with wipe on poly or an oil and put on the shelf in a warm (60� or so) dry place.
After 2 weeks check the MC and the dimensions. When there is around 1/8" difference in the dimensions re-mount and re-turn to true. Then do the whole thing again. You will find the intervals between turning get shorter as the MC comes down. Continue until desired finished wall thickness is achieved and MC is down to around 10%.
Total time is usually less than 3 months. End result is a dry symmetrical bowl with no cracks and no voodoo or messy liquids. The only drawback is keeping records and setting up a routine that ensures a steady flow of work all going through the same process.
Usually the MC drops quickest at the start then the rate of moisture loss slows. It's the fast drying that usually causes the cracks. Because you are decreasing the thickness of the wall in gradual amounts this speeds up the drying process and at the same time the thinner wall is less prone to cracking.
Patience is a virtue
Even though I always try to turn green all the way to finish, waiting a week or two before signing and putting a finish on requires a little patience.
Maybe I am just crazy, but I have always liked the shrinkage out of round. That is just an acceptable part of the medium. And just placing the turning inside a paper bag is all I usually do.
Back when I did a lot of larger hollow vessels with smaller openings, I wondered if getting a bit of air moving on the inside might speed drying, plus relieve a little stress on the outside, so I made a simple device. I made a box with a PVC tube coming out the top. The box was open on one side, and the PVC had cuts on the top, leaving little fingers to hold the turning up, but allow air out inside. I would place it in front of my refrigerator where the warm air blows out.
This slightly warmer air could gently flow through the inside of the paper bag wrapped turning. It worked. Actually it worked faster than I expected, and when I left one there all night, I did have some inside checking. At least the checks didn't show on the outside. If any of you decide to try this, I would suggest that you only leave it in front of the fridge for a few hours per day. And don't blame me if that is too much. K
robo hippy
I happen to love warped bowls, and they sell very well for me. (old hippys never die, they just move to Eugene where tie die is the official cammo). Some thing about the 'organic' shapes really appeals to most of my customers. Advantage: they are dry enough to sand out in 3 or 4 days, and totally dry in about 10. Disadvantage; you need slow lathe speeds for sanding, or use the spindle lock.
Hey Steve, if you are losing a lot of bowl blanks, like more than 10%, try wrapping the rims in plastic stretch film like I do, and STRETCH IT OUT a couple of times around. 6 inch wide, and stretch it out. You do round over the rims don't you?
robo hippy
Steven Antonucci
soaked right into the ground
steven antonucci
I kept the pail outside for that reason. it had probably diluted from the bowls that I had soaked, but still I didn't want to take any chances.
Smelled for less than an hour...
S
Steve Kubien
That's one reason I stopped DNA
Steve Kubien
I used the DNA soak method for a little while. Like Steve A. said, works great. BUT, I was rather nervous having the stuff around. Just wasn't comfortable. I was gifted and old fridge and decided to make it into a kiln. Mine is a lot simpler than some folks and I have not even had to wire a single thing. Simply a light fixture, already with a cord on it, a desk fan and a digital thermometer which also reads relative humidity. The cords run through the seal on the door and go straight to a socket. It works great, is far safer and when all is said and done, only takes an extra couple of weeks to go from green to dry.
Barry L Elder
Not meaning to give offense to any woodturning brethren, but I find the term "instant gratification" seems to describe much of our shallow society today. I much prefer to seal wood and let it season for a year or two, rough it, bag it with chips, and check the weight every so often. Then when I finish turn it, I can stop and admire the grain, knots, character flaws, operator errors, and see what God has made for me to practice on. Potential clients always want to know the "story" of each piece, and turning wood salvaged from trees destroyed by hurricanes, each piece is truly unique, even if my skills are not top-notch. (But I have lots of sandpaper!)
Don at Central Illinois
Barry, I believe that is called 80 grit gouges.
