Help the dummy, please!
Ed Moore in SW VA
I am convinced that I have seen drill bits, possibly ball end mills, with a Morse taper shank. They cut a round bottomed hole.
1. What are they called?
2. Where might I find a 1" diameter drill as described?
I understand that they might be prohibitively expensive.
Thanks,
Ed
Re: Help the dummy, please!
Mike Foster
Did you try a search at Mcmaster Carr for end mills. I know they have them.
Mike
Keith Newton----Little Rock, Arkansas
You can probably find that as MSC, but are you using it to cut wood?
If you are, I would bet that you can find a 1" core box router bit, that will cut faster and be cheaper.
If you want to share what you are making, helpful hint flow freely here.
Ed Moore in SW VA
I would use it to drill out acorn birdhouse ornament bodies.
I might have a router bit such as the one you mentioned.
Thanks,
Ed
Ed They are called Ball End Mills. In that size they run from about $200 to $350 just glancing through the catalogs. They will cut at slower speeds than the router bits and don't chatter as much. Not sure about how clean they cut but not bad based on the smaller ones I have.
The router bit from MLCS is called a Core Box bit and they run about $20 for that size.
Mike Stafford
Re: Help the dummy, please! *LINK*
Mike Stafford
Professor Moore, Craft Supplies offers drill bits, normal twist drill bits with Morse #2 shanks that fit directly in the tailstock.
These range in size from 3/8" to 1" in size and from $12.99 to $33.99 in price which is almost affordable for what you want to do.
Here is the link....
Morse Taper Drill Bits
Emmett Manley, Lakeland, TN
Ditto to Professor Moore. I have purchased three of the Craft #2 Morse taper drill bits and, although they are made in China, I have been pleased with them. The one inch bit is about $34.
I have a core box bit that cuts round bottom holes that is about 1 1/2" in diameter. Might be 1 5/8", I'd have to go look. It has a standard half inch shank. I put it in a Jacobs chuck that has a Morse Shaft. I turn the body of the ornament and then drill it out with the core box bit. I crank the lathe up to full speed and drive the bit in with the tailstock.
I have also made ear ring sized bird houses using a 3/8" or 1/4" core box bits. You can buy numerous sizes of core box bits, but I don't think they are available with Morse taper shanks. They really make quick work of ornaments.
Thanks, Mike and Emmett!
Ed Moore in SW VA
I haven't seen round end ball mills with morse tapers. The end mills I've found so far have They might exist but haven't found them yet. I did find an round end mill in 1" for $57 from Enco. It has a 1" shank which will be a little hard to use. You can buy end mill holders with #2 morse tapers but that adds more to the expense.
The Core Box bits come in 1/4" and 1/2" shanks. I'm a little worried about how they will cut at the slower rpm's but they will probably work.
Another option might be a spoon bit but I'm having trouble finding them in that size. Lee Valley only sells up to 5/8". They are designed to use in a hand brace but you could probably figure out a way to chuck them up.
Thanks, All!
Ed Moore in SW VA
The best approach is probably to drill out a portion of the hole and then clean up with a core box bit or round-end bit of 1" diameter.
Ed
Steven Antonucci
Have you thought about making a reamer?
steven antonucci
You could probably make a reamer out of an old spade bit in about 30 minutes? I'd hollow with a gouge and then ream the inside before final turning the outside profile.
If you wanted to go the more conventional route, you could make a small hook tool and get great results. I use them to make goblets all of the time (same as above...)
Steve
Mike Stafford
Re: Thanks, All!
Mike Stafford
Professor Moore,
I know you are not an advocate of scrapers but this is an application where scrapers will do the job. Scrapers do an admirable job in end grain situations.
If you were to drill the main body of waste out and then use a scraper to refine the internal shape I believe you would be happy. Shaping the inside could be done very quickly. It would be very easy to grind a half round or French curve profile on a 1/2" scraper.
Of course it would only cut on one side. I am not sure how you would cut the other side.... :b
There's a second application ...
Ed Moore in SW VA
that I have in mind which requires a deeper cut, which is why I wondered about the Morse taper bit with a round end. A drill chuck would not let a core bit go deep enough in this case.
I currently hollow the acorn bodies using a drill and then cleaning up with a scraper. Because the bodies flair out a bit as you go deeper one would still need to adjust the hollowing with a scraper, but it would not involve the bottom or center area.
I may try Steve's idea of grinding a spade bit to shape. I would expect the bit to wander and pre-drilling might be dicey.
Thanks all,
Ed
Crafts USA
Jorge Casta�eda
Ed,
check the wodturners catalog...
Re: There's a second application ...
I've tried modifying space bits. They chatter like crazy and that still had the center spur. I was grinding one for a candle taper. I thought I ground the sides pretty accurately but then that was by hand. When I got the metal lathe I rigged up a grinder to the tool post and reground the bit. It reduced the chatter a lot. That was an easy bit to grind because I had straight lines. It would be very hard to grind a spade bit into a circle without the center spur and not have it chatter. Without the center spur it might not track very true either.
Still it wouldn't take very long to try. If you could rig up a jig sort of like a circle jig on the bandsaw then you might be able to grind the tip in a very consistent arc and make it work. Just drill a hole about a half inch from where the new edge will be and centered. Then drive a nail in board through this with the steel hanging over. Then take it to the grinder and start swiveling.
If you start with a pilot hole in the work it may track straighterwithout the spur. I'll check tonight. If I have a spare bit that I can waste I'll make one.
Steven Antonucci
not with the lathe running...
steven antonucci
I wasn't suggesting to make a reamer to be used under power, but merely to be hand reamed at the end. A chairmaker I know swears by them, and his reamer is a dowel with a small blade down the centerline. It might just be an old planer blade.
S
Chuck Engstrom
Hi Ed -- you might try wandering around on ebay and its stores for a few minutes -- all sorts of stuff shows up there, as I'm sure you know, and there are stores specializing in surplus tooling from the aircraft industry etc, where you might find some special drill that's just the ticket for what you want to do.
Local friends just came back from last weekend's "Cabin Fever" gathering up in York, PA, which seems to be mainly a big swap-fest of machine shop stuff. There's probably something like it sometime down near you.
Best--
Chuck
Bill Turpin in WNC mountains
What about Craft Supplies' thimble cutter? At ~$66, they are expensive, but they work well. They cut centered without a pilot hole. Wife has sold about thirty thimbles in two years. This is a good way to use up small pieces of pretty wood. A little off-center chucking could provide a larger hole.
Chuck, good idea! I never ...
Ed Moore in SW VA
think of checking out Ebay or Craigslist, or anything like that.
I miss the restaurants at Kent Narrows.
Ed
Bill, that's an excellent idea ...
Ed Moore in SW VA
I had not thought of a thimble cutter.
How thick does your wife make the thimbles? Having a needle punch through into the finger does not appeal to me.
Ed
Re: Bill, that's an excellent idea ... *LINK*
She makes them about a tenth of an inch, sometimes less. In softer woods, like zebrawood, she will soak the tip, inside and out,with thin CA. She then turns several concentric circles in the ouside tip to make push points for the pins. She works with seven quilters who collect them. She gets $12 for them, but the wood is free at this point. She also sold several to turning club members who did not want to buy the cutter.
CS thimble instructions
Matt Birchfield
Ed,
Try Mason Mechanical Labs in Salem... I assume that they're still there... for used and sharpened bits of all shapes and sizes. I've purchased many MT drill bits there, including my 12" long X 1-1/2" #4MT bit. It cost $12. They have bins of bits you didn't even know you needed!
Ed Moore in SW VA
Bill,
I will admit that I just ordered the bit. I had already thought of the thin CA glue as a necessity. Thank you very much for the instructions.
Looking forward to seeing you at the NC Symposium!
Ed
