I just made a flat 15" vacuum chuck to help with finishing the bottom of bowls. I bought a 8" x 11" pack of sticky-backed closed cell foam. Would it work if I pieced the sheets together to cover the entire chuck or would there be leaks between the sheets? Should I just try to find a large sheet of foam to cover the chuck so there will not be any seams where the foam sheets meet? Thanks for your help.
I use clear silicone caulk to join areas of material that I use for vacuum chucks. This goes from sealing the ends of O ring type material to joining narrow strips of foam across round chucks. It works like a charm.
Tomm, my suggestion is to look around for a sheet of foam that is large enough to cover the chuck without having to worry about seams and so forth. Nothing fancy is required in the way of foam as long as it has a film surface. A lot of packing materials can be used.
The foam underlayment for an engineered hardwood floor (the snap together kind) is ideal. It is an eighth of an inch thick or less and very sturdy with a film surface on each side. A roll of it would last you and all your woodturning friends a lifetime.
You don't need sticky-back foam. A strip or two of double sided tape to hold the foam on the plate while you are installing the bowl is all you need.
I'm curious Tomm, why such a large diameter? If you are chucking on the rim, the wall thickness of the bowls should be fairly substantial, or you may crack it under vacuum. Most people I know, use a longer snout and chuck to the bowl bottom. Also, the rim has more chance to warp and make for tougher chucking. Maybe you know all this and I'm just spitting into the wind, but wanted to share ideas.
I am a bit surprised a reply like yours didn't appear sooner.
When I started vacuum chucking I made a flat plate with foam on it as well as some drum (long snout) chucks out of MDF and black ABS connectors. Apart from testing the flat plate everything has been held using the drum chucks I made.
I can see where it might be handy for something that doesn't work with the drum chuck but it is likely to be something that is smaller rather than larger I think.
For large area thin devices putting the whole area under vacuum does risk cracking so be sure to have an air-bleed to keep the vacuum from exerting too much force over the area.
