Glue fumes
Glue fumes
Glue fumes
Joe Dickason
Does anyone have any magic for dealing with glue fumes in a small area, outside of just moving a lot air?
Re: Glue fumes
Re: Glue fumes
Ken Ward
What kind of glue are you talking about?Whatever it is,if its that potent,then either find another type or put some type of vent in and a good fan.
Re: Glue fumes
Re: Glue fumes
steve worcester
I am going to guess CA glue, and you can usually turn on the shop vac close to it and it will suck the fumes out. Maybe not good long term for the vac, but lungs aren't cheap either
Re: Glue fumes
Re: Glue fumes
Like Steve I turn on the shop vac but a small fan blowing it away also works well. The best bet is to use it in smaller quantities. it doesn't fume up as bad when you do that.
Re: Glue fumes
Re: Glue fumes
bill Crommett
I spend a lot of time cleaning off the ways of my lathe, because that is where I do most of my CA gluing with the dust catcher on full blast.
Re: Glue fumes
Re: Glue fumes
Doug Turner
CA glue requires at least a charcoal filter to absorb the fumes. Better is fresh breathing air piped in from outside the area. CA glue was used in combat to seal wounds because it reacts instantly to moisture, and your lung passages are coated with moisture to allow the exchange of gases. Some of the penturners have developed hypersensitivity to CA and say that"odor free CA" allows limited use with adequate ventilation.
Re: Glue fumes
Re: Glue fumes
Dave Belser
I do a fair amount of work where I uses CA glue when creating a number of different structures that I turn. This usually involves hours of work at a table or bench. Not much different than building an airplane model (which I used to do).
What I do is set a large box fan up on one side of my work area so that it is exhausting away from me and run it at a low speed. You really don't need much just ensure that you have a draft over the work area.
I used to do this only if I was getting a lot of fumes but I started noticing an allergy like reaction the following day - so now I use it all the time. I have a relatively large shop area (20x30) so just a positive air flow away from the work is sufficient. In the summer I make sure there is fresh air.
Note that this is only normal assembly type work. I have other processes that require soaking work with a fair amount of thin CA. This can be quite nasty in regards to fumes and I only do this outside - in a breeze - and the work stays outside for a while.
Re: Glue fumes
Re: Glue fumes
Joe Dickason
Thanks for the input. Pretty much what I had figured. We use a lot of CA @ my work to bond rubber to plastic. We are in the process of upgrading the ventilation to get it outside. Just was hoping that someone had a "magic stone" Thanks again
