Paper joint candle holders
Sometime in the late 80's I learned about using paper joints in woodturning. I found this image while cleaning the house. Obviously I did these shortly after doing the other wall mounted candle holders I posted. This is still a good project for beginners.
for the back plate glue 2 pieces of walnut together with a scrap of wood inbetween. put newspaper or brown paper between the wood while you glue it up. Add more scrap wood to the outside. Then just turn it between centers. Turn the ends down as small as you dare. You'll have to carve away the very top and bottom after removing them from the lathe. Stick a chisel or knife in the paper joint and drive it down through. The should pop apart. Soak the glue and paper with White vinegar and you should be able to scrape it off.
For the candleholder glue 2 thicker boards together with the paper joint. Turn this between centers and carve away the waste just like you did above. Remove the glue. Drill a hole in the top for the candle glass.
Now just glue them onto the backing plate. For these I caved out a dished area and colored it gold with paint.
