200+ woodworking book reviews
Simulating rust on wood
Mac Ray
Can anyone here give me a source for the products needed to simulate rust on wood,and maybe the procedure involved,thanks....
Re: Simulating rust on wood
The product that I have used(several .....
JamieDonaldson
..years ago!) is made byTriangle Crafts, labeled as Sophisticated Finishes, and is called rust antiquing solution. I bought it at Michael's here in KY, so it must be readily available. There are several other similar products like copper, etc. in their product line.
Re: The product that I have used(several .....
Mac Ray
Thanks Jamie,I'll try to locate that.......
Model Railroading
Tony - Memphis
Might check your local hobby shop for rust paint. I used to use several different products to simulate rust when I was into the hobby.
Tony
Steven Antonucci
Not simulated, but actual rust
steven antonucci
I use Iron based paint from SculptNouveau.com (B formulation) with one of the patina sprays or my own brew (Ammonia and salt or vinegar and salt).
It deposits like paint to a battleship grey and then rusts in brown/orange variations.
Steve
Chuck Engstrom
Hi Mac -- A couple of years ago I bought a rust paint "kit" made by Krylon or Valspar or one of the main manufacturers, can't remember which for sure and can't put my hands on it at the moment. I think you could still find this in a big-box store or local True Value, Michaels, etc.
As I recall it had two spray cans and gave a pretty decent result. There were also fake marble, etc etc.
I worked in a shop that made custom lighting where the boss's daughter did a terrific fake rust with drywall mud, glass blasting beads, and various colors of enamel. It looked like it had just been rained on, better than the kit results by far. You could try experimenting along those lines.
Best to all--
Chuck
Modern Masters *LINK*
Jennifer Indy.USA
Mac,
We've been playing around with and really getting some neat effects with a product from Modern Masters. They have a variety of different metal effects products and our favorite is the rust simulator. We've tried them all. You can find them on line or so we've found little out of the way shops.
Jen
HERE'S A LINK TO THE RUSTY STUFF
Re: Modern Masters
Mac Ray
Thanks for all the help,I have enough leads now so that I'm sure I can locate something I can use,thanks again........Mac
Leo Cuellar
For Mac Ray: Modern Masters... My test *LINK*
Leo Cuellar
Hi Mac. I had placed an order for some of the Modern Masters product just before your post. I found out I should have ordered the primer as well, so had to wait for that. Anyway, here are a couple pics of my first attempt with it. I think Maybe I should have applied 3 coats of the metal paint. I had to spritz it with the acid solution 6-8 times to get it to develop well.
The paint doesn't like to be touched while the acid is on it, slides right off the primer :\ Durable after it dries though.
Here's a link to the place I got it from.
The Faux Shop
Re: For Mac Ray: Modern Masters... My test
Mac Ray
Thanks Leo...I have placed an order and will let you know how it works for me as soon as I give it a try....
Chuck Engstrom
Hi Mac -- I see you're underway on this. Here's the product I mentioned but couldn't put a name to when this first came around a while back -- I just came across it in a cabinet. It's put out by Rustoleum and I got it in a big box store. I did try it once but can't find that sample piece. It was pretty decent as I recall.
Best--
Chuck
Mac Ray
Thanks Chuck, If the one I have doesn't turn out as I want, I'll try to find some of that one..........
