As some of you may be aware I regularly test products and submit my findings to "Woodturning" magazine here in the UK.
I am about to test run Pentacryl, Polycryl and Wood Juice from the USA.
They are not very well known over here and since it is an American product I would appreciate the views of those most likely to have tried it for themselves.
I have studied the web site of the manufacturers and will of course have my own findings eventually but I would really appreciate personal experiences from you.
If you think the products are rubbish, I would still like to know your reasons.
I have a limited amount of each for test so will be using ONLY a brush method with each.
Please email me, unless you feel your experiences are of use to the members of the forum.
Pentacryl is the only one of the products that I have any experience with. I first became involved with in in 1998. In August 1999, I published the following:
Pentacryl is a different product that can just be painted on the wood. You should paint it on until the wood will take no more. I recently turned (1999) a wet redwood bowl, rough turned to a 1-1/2" wall thickness and painted with
Pentacryl. I dump some Pendacryl into the bowl and paint the inside and then
held the bowl up and painted the outside.
The endgrain areas are most important. I sat that bowl on the shelf and two weeks later it was very light. So, I final turned it, the chips coming off were dry. On a 15 inch diameter rough turned bowl there was a 1/8" difference between the two directions. There were no cracks and it sanded very well. I had to cut away the pith which had a damaged area so that the final diameter was 13-1/8". I did the same with a walnut bowl, but haven�t final turned it yet (in 1999). It doesn�t seem to be cracking nor does it seem to be warping much. Other than some top blanks that dried in about a month, without cracking, and turned beautifully, I have no other experience with Pentacryl. It supposedly stabilizes
wet wood, but I don�t think it can harden punky wood. It doesn�t seem to
affect any finish material that I�ve tried, but they say it can give you problems with sanding. I had no problems on my stuff.
Incidentally, the walnut bowl turned out very good. That was eleven years ago.
You might like to try Cedar Shield also called Turners Choice. This product is for use in treating green wood. Made by Cedarcide in Texas. I use it a lot and am very pleased with the results. Soak for 24 hours wait for 72 hours and turn no matter how green. No split, cracks and very little distortion.
