It is amazing what you learn when you actually do something compared to just reading about it. I bet I have read this before on this site but� I wanted to try out using shellac for the first time. So while at the store I picked up a can of it and made sure there was no mention of wax on the can. Brought it home and thinned it down some and put it in a clear container.
Well while working at my desk today (for my real job) I happened to look over and saw how there was white stuff at the bottom of the container.(I get side tracked for the important stuff) Started checking around and found out if the manufacture does not say anything about wax that means it in there. I should have looked for the can that said no wax.
Now is this backwards or am I just getting old and cranky? (maybe even both)
But if you REALLY want to have fun - get dewaxed shellac flakes - maybe even get several kinds - Platina, Super Blonde, Orange AND Garnet. To make up what you need - plus a little - weigh out your flakes - put them in your electric coffee grinder (you DO have an electric coffee grinder right?) and turn the flakes into powder. Measure out your alcohol and put it in a small mason jar then pour in the shellac and put the lid back on. Shake things up for a minute or two, set the jar down and come back in half an hour and shake it some more. Do that a few times before bedtime. In the morning you'll have your very own MIXED IT MYSELF SECRET FORMULA BUG SPIT FINISH.
If you get really into shellac - have a go at French Polishing. Guaranteed to lower your blood pressure - and maybe cramp a finger or two. Very meditative exercise - and you can produce a Mile Thick looking finish - that's repairable.
I use a thinned (2 parts DNA to 1 part liquid dewaxed shellac) as a spritz in areas that need to be filled with dust and CA. The shellac seals the area and prevents that nasty CA stain. Later sanding will remove any hint of the shellac sealer.
Yes, shellac is definitely fun to play with. The flakes are translucent - and pretty to look at. It's one of the few finishes you can EAT - and probably have - unknowingly. "Coated" pills often are coated with shellac, as are some apples in your grocery store. And the ritual of weighing, grinding, stirring and swirling - watching the beautiful "liquor" develop - becoming less and less cloudy as the shellac dissolves into the alcohol - has a Kid's Magic quality to it. Watching the surface change as you build it by rubbing the shellac into and on it - rubbing in small circles as you press down on the "pad" can be mesmerizing - almost hypnotic.
Yes, I've used shellac on some of my turnings and it holds up well - assuming you don't abuse it. By abuse I mean - soaking it in water or putting jagged rocks in the piece. Wiping it with a damp cloth or paper towel and then drying it is no problem. It is a "hot finish" meaning that as you build a finish with it, each new application dissolves a little bit of the previous surface - forming a continuous layer of finish (as opposed to acrylic or poly finishes which build in individual layers, held to the previous layer mechanically by the sanding scratches you put on before applying each coat). With "hot finishes", if its solvent gets on the surface it will dissolve some of the surface. But, unless you drink MoonShine or do your nails and spill nail polish remover on it - you're not likely to harm a shellac finish.
Unlike acrylic and poly finishes which produce distinct layers in the finish which when sanded leave visible "contour lines" where you sanded through the layers, "hot finishes" are easily repairable. Scratch the piece a little and you merely sand that areas and apply another coat to the area - no "contour lines".
As for shellac "popping the grain", the "popping" is a matter of getting more finish in the end grain than in the side grain - kicking up the contrast between the two. Alcohol, the solvent for shellac, has a pretty low viscosity, as opposed to boiled linseed oil (BLO). As a result, it will soak farther into end grain than a more viscous liquid. Multiple applications of Garnet shellac and then sanding it off the side grain, leaving it in the end grain will "pop" the grain. See the bottom two images on the attached page. The bottom picture shows the effect of applying garnet shellac. I did the other sides with Platina shellac and got a more subtle grain pop effect. The key to popping grain is to get a darker look in the end grain and not in the side grain. Go dark first, remove the dark from the side grain, then apply the lighter colored shellac.
Thanks Charlie I got to try this. When you say sand it what are you using? With Lacquer I wet sand, can that be used with this or is it better to go with something else?
Zinnser Seal Coat is dewaxed shellac. I use it all the time with excellent results. Just make sure you check the date on the top of the can; it has a 3 year shelf life. Lots easier than using flakes, and it is "almost" colorless.
"When you say sand it what are you using? With Lacquer I wet sand, can that be used with this or is it better to go
with something else? "
If you just want to "pop the grain" by dyeing - you can stop at 220 grit - 320 grit if you're Anal Retentive. If you want a really shiny, no visible scratches look - sand to your heart's content - say 12,000 grit - then spray on a clear coat and continue on with "rubbing compounds" to what ever smooth and shiny level you want.
I've done some illustrations with accompanying text that shows and describes how "popping the grain" using a dye works.
