Buffing questions
Buffing questions
Buffing questions
Starry S Chan
I have both the 8" wheels and 3" bowl buffs. The instructions from Beall state that motor speed should be 1750RPM for 8" wheels and 3450RPM for bowl buffs.
Will there be problems or issues if I run the motor at 3450RPM for the 8" wheels? This way, I will not need to change speed when I buff the inside and outside of a bowl.
Starry
Re: Buffing questions
Jim Sebring
I'm continually surprised by the instructions given by different suppliers for the same type of equipment. I've used the Beall 3-on buffing system on small items like pens, but I don't remember the speed. I've since changed my buffing system over to Don Pencil's individual wheels and balls for use on bowls. He recommends 1200 rpms. I use the same speed with either the wheels or balls. Just use a light touch.
Steve in Durham NC
I use both the Beal wheels and buffs on my lathe at about 1200 - 1500 RPM. I find that that slower speeed allows the wheels flex a bit more which in turn allows them to conform to the shape better. It eliminates hot spots.
I will turn up the speed a bit on the bowl buffs at times when waxing but I never go above 1700.
Steve
Alan Zenreich
Alan Zenreich
It's all about finding the right feed rate based on the inches of material traveling under the work being buffed.
An 8" diameter wheel has a circumference of roughly 25" (pi x 8").
At 1750rpm, the feed rate is 43,960 inches per minute (recommended rate).
At 3450rpm, the feed rate is 86,664 inches per minute (pretty darn fast)
A 3" diameter bowl buff has a circumference of roughly 9.4" (pi x 3").
At 1750rpm, the feed rate is 16,485 inches per minute (pretty slow).
At 3450rpm, the feed rate is 32,499 inches per minute (recomended rate)
A 4" diameter bowl buff has a circumference of roughly 12.5" (pi x 4").
At 1750rpm, the feed rate is 21,980 inches per minute (pretty slow).
At 3450rpm, the feed rate is 42,332 inches per minute (recomended rate)
The wheel material isn't changing, but the way the wheel works is greatly affected by the rate of feed. Find a combiation that works best for you.
Bill Howatt
If a manufacturer states the max rpm for a rotating object, I would stay below it. Granted, it is only a bunch of cloth but it could still fly apart and you are very likely to quickly get hot spots.
As was stated earlier, the wheel gets less flexible the faster it goes and it can be very handy to have some flex especially if the bowl is a bit on the small side for the wheel. You do want a higher rpm for the smaller buffs.
I do my buffing on an electronic variable speed lathe so I can easily adjust the rpm.
More work but setting up a pulley system with a step-pulley on a mandrel will give you some adjustable speeds.
Bill
Dave Gelnett
I have found that when people first start to use the buffing system they tend to stay in one spot to long. With a lacquer finish thats is a real problem.
So I have been recommending with friends here local to use it at 900 to 1000 rpm (with wheels), and then speed it up as they get use to it. Also if the area you just buffed is turned toward your hand where you are holding the peace that will let you feel how warm to hot the finish is becoming. That way you can tell if you are staying to long in one place.
Bernie Weishapl
I use my 8" buffs and the bowl buffs on a 1750 rpm motor. Haven't had a problem using either.
3450 too fast for 8" wheel
bob davis
too easy to burn finish off
Ric Taylor
Ric Taylor
RPM that high will melt through some finishes, such as lacquer, then you have a real mess to clean up and start over. Stay away from the high speeds.
Ric
