Carved end grain butternut vessel
Donna Banfield
Below is a photo of a recent end grain carved vessel. Wood is Butternut, rough turned as a green log, end grain orientation. After drying for about 6 weeks, the vessel was turned a second time to final thickness -- about 3/8 thick. While still mounted in the chuck, the leaves were sketched on the exterior, and I used a jig saw to cut out the exterior of the leaves. Having an articulating jig mounted in my tool post allowed me to flip the vessel 90 degrees (or onto it's side) making the jigsaw cutting very easy.
The remainder of the carving was done using my NSK EVOlution carver, with carbide bits. Thank you Ed Kelle for your advice on carvers. This is the upgrade that I purchased when I burned up my WeeCher. Sanding was done using Jennifer Shirley's suggestions (per J. Paul Fennell) of small abrasive discs attached to flat head nails using double stick tape, and held in my NSK. Sanding using this method took less than a day. The carved vessel I did immediately previous to this one was entirely hand sanded and took a week!
Dimensions are 8" high by 6" wide at the tips of the leaves, finished with several coats of Bush Oil. Comments and critiques about turning/carving/photography welcomed.
Close-up view:
Re: Carved end grain butternut vessel
Jim Rutten
Hi Donna,
A name just popped into my head: "Tempest". The leaves, to me look kind of like the tips of waves and even the grain pattern which is docile under the surface explode when getting up to the waves. Congratulations, this defintely looks like a 'signature' piece.
Very nice!
Todd Nebel
Very nice, pretty grain
Don at Central Illinois
Beautiful. Planning on trying some carving this summer. You have given me something to aim for.
Mike Foster
Nice piece Donna. It is a tribute to your patience. I have done a few pieces in butternut, but is not one of my favorite woods. I did a bunch of bowls a couple years ago from a tree that fell on my property. I would not rate that as fun. Tear out is almost inevitable even being very careful with very sharp tools. I imagine turning end-grain worked a little better. Sanding is definitely the key and you did a wonderful job of it. I, too, have found Jennifer's sanding tips useful, but modified it slightly to the equipment I use. The idea is the same.
I like the piece. The contrast with the late wood/early wood is striking, especially since it is so well sanded. I did not think of leaves when I first saw it, rather flames. It doesn't really matter as it looks great and leaves it open to the viewer to see what he/she wants. Nice. (BTW be careful with that piece, butternut dents easily)
Mike
Donna Banfield
Thanks everyone. I am pleased with how the carving 'turned' out.
Mike, butternut is not the easiest wood I've turned, green or dry. But it carves like a dream. I have a few more roughed out vessels from the log that I acquired last August, and awaiting inspired carving.
john lopez
Very nice...
the swirls in the grain enhance or compliment the carved rim
giving it a balance and also a feeling of movement.
B. Leathers
It's beautiful and it must have taken a lot of coats of oil being porous as it is.Good job and something for others to strive towards.
