coloring ca glue
coloring ca glue
coloring ca glue
James Pittman
Can you color thick ca glue and if you can what do you use to color it and does it change how it works. Thanks Jim
Re: coloring ca glue
john lopez
You can grind & mix in instant coffee crystals for a dark brown or black.
For a teal I'm playing with some old copper tubing & vinegar to make verdigris.
Google "making verdigris" It's toxic but what isn't? It's easy to do.
You can also mix in brass, glitter, stone, abalone.
I remember someone doing inlay work and using spiders to fill a void.
There are probably other materials...
some will work better than others...
the sky is the limit.
CA does stain wood so mask the area with blue tape.
Dick Coers
I'll try and find the info, I think it was on the IAP site, but you can't add color to the CA. I Googled "adding color to CA" and found several posts saying everything from; it lost strength, to took 3 times as long to set up, to set up instantly and metal the plastic cup. Coloring epoxy works well.
Bill Howatt
You can apparently buy black CA. I have always been under the opinion that you should not fool with the glue itself for fear of upsetting its chemistry such that it will setup before you apply it or it will not hold at all.
You can of course pour it onto various materials packed into voids and recesses to hold them in place.
Bill
