My friend has a Shopsmith and wants to learn to turn. I will give him all the help he needs, however the Shopsmith isnt the ideal lathe, but I need a chuck adaptor or something that will work to turn bowls? The shopsmith if not familiar, is a all in one. Basically a drill press laid on its side. Here is the problem the only fitting is a #2 morse taper on the drill press head. Any ideas what would work to hold a chuck or other to hold a piece of wood? Thnx R
I was also going to suggest the 5/8"-plain shaft adapter that is available for several different chucks - these are supposed to be compatible with a Shopsmith used in the lathe configuration.
Alternatively, you might have a machinist turn a Morse 2 taper on a long-shanked 1"-8 tpi bolt, upon which you could thread a 1"8 nut and a 1"-8 chuck of your choice. I do see a problem with this if the MT2 to 1"-8 adapter is not used with a drawbar - the adapter-chuck-blank unit could come off of the lathe if the taper junction loosens. Not a problem if you're turning between centers, but perhaps not particularly safe if you're turning a bowl/vessel with headstock support only.
Ya, Thanks guys, right now he is just learning. I checked the shopsmith accessory link and yes that looks like the way to go but pricey for someone starting out. However, I did see a morse taper adaptor with a 1x8 threaded end in the catalogs. Seems like a cheap way to go, but as stated this would work well for between centers, but sketchy as a stand alone way to hold a bowl blank on the headstock? Thnx for all the help, I will discuss the options with him. THNX
Shopsmith has a 5/8 smooth thaft with a flat spot for a grub screw.
Never has had a morse taper --
Look at a small chuck since the bearings are not designed for lots of weigth. It is really a spindle turning machine or very well balanced small bowl blanks.
Have a '83 version parked in the garage for sanding and bandsaw attachments.
Ya your right about no taper, went and looked at it today. He doesnt have the faceplate attatchment so ill help him find one. Thanks for all info, gave him some wood and books and videos today. He seems stoked. As we all know this could get ugly! I have been turning for a long time and I still drag home logs from strangers front yards and stock pile them in my garage! I hope the fever catches!
