Coloring Epoxy
Coloring Epoxy
Coloring Epoxy
Tony - Memphis
I did a search here the other day looking for some ideas on how to tint epoxy. Got some good ideas - thanks all. I am turning some of those laser cut pens and needed some black filler for the seams. I tried ground up pastel chalk and it worked very well. Didn't take much either. I just used sandpaper to "grind" the pastel and collected it in a cup. Then mixed it in with 5 min epoxy and it worked great.
Tony
Re: Coloring Epoxy
Re: Coloring Epoxy
Tony It does work well and so does copier toner. They both thicken it slightly. If you still need thin epoxy try using Feibings black shoe dye.
Re: Coloring Epoxy
Re: Coloring Epoxy
You may have used too much or it could be the brand of epoxy. I use West system and have used System 3 and both worked fine. I have also tinted a lot of the cheap syringe types with shoe dye. It doesn't take much.
Re: Coloring Epoxy
George Taylor
Black CA glue
George Taylor
There is also black CA glue on the market (Starbond?); our club got some samples ... have not tried it yet.
George
Re: Coloring Epoxy
Richard Allen
Re: Coloring Epoxy
Richard Allen
I "wet" the surface with epoxy. Then add a little filler to the epoxy and add a little dye to the epoxy and apply that.
The wetting forms a barrier to the colored epoxy so the color doesn't bleed into the wood.
The filler makes the epoxy opaque.
The dye, I use powder reactive dye in very small amounts, to add the desired color to the epoxy.
I use west system epoxy with the slow hardener. I have found that the 5 minute epoxy never gets hard.
Re: Coloring Epoxy
Re: Coloring Epoxy
Richard Which 5 minute epoxy are you using? I have used various brands of 5 minute epoxy and also West System rapid hardener. The only time I've had trouble with them not getting hard is when I used the wrong mixture.
I have had problems when I mix too much colorant or particular types of colorant.
Re: Coloring Epoxy
Richard Allen
Re: Coloring Epoxy
Richard Allen
The non-hardening of 5 minute epoxy I used was system 3 "Quick Cure".
I went through most the the epoxy over a year and I never tried it again.
Perhaps my observations are the result of old glue.
Re: Coloring Epoxy
Re: Black CA glue
Emmett Manley, Lakeland, TN
I received some black CA glue as a Christmas present. Without the accelerator, this CA glue did not cure overnight; whereas, the usual CA glue sets up in a matter of minutes, if not seconds. My black CA glue also shrunk a lot. Bottom line -- I am very unhappy with the black CA glue I have. Mine came from Craft.
Re: Coloring Epoxy
Re: Coloring Epoxy
Richard I go through glue so fast it never gets old. When I have a problem with non hardening glue it's usually been that I mixed too much of something else into it or I possibly mixed uneven quantites of A and B. I suppose old glue could be a problem. Maybe I need to buy larger quantities. :)
Re: Coloring Epoxy
Ric Taylor
Re: Black CA glue
Ric Taylor
My experience with the black CA glue from Starbond is that it shrinks over time, long after the piece is finished. I won't be using it again.
Ric
Re: Coloring Epoxy
Jim Evans
Re: Coloring Epoxy
Jim Evans
I have had good luck using Jaquards Pearlescent powders. For most of my coloring I use the end of a Popsicle stick which is about 1/4 teaspoon full.
Re: Coloring Epoxy
Jim Evans
Re: Coloring Epoxy
Jim Evans
Dang I forgot the link.
http://www.jacquardproducts.com/products/pearlex/powders/
