John's post below brought up an interesting question for me, as I have gone from Space to Convenience and I am now heading back towards Space...
Is your shop set up for space considerations or convenience? Which dominates?
I am in a one car (15'x24') and I am set up all screwy for the way that I work. I got this way over time quite by accident, and I am slowly working my way back to being space sensitive. On an average day, I have no reason to own a planer, jointer, drill press, mortiser or tablesaw- but I do and they consume far more real estate than I would alot if starting from scratch.
So how is your shop laid out? How did it get there?
Probably like most turners, I was more into flat work when I started and then they joy of not having to make things square took over and the turning addiction started.
I am rather lazy and knew that if a tool was not convenient to use I would find an easier way of doing the task. Often the easier way wasn't but I just don't like taking a lot of time setting up tools.
My biggest mistake when creating the shop was cleverly finding places to put all the large tools and then realizing that there was insufficient room to assemble even a not overly large project.
I put an extension on the house that conveniently made my basement shop bigger so I solved the problem.
Anyway I like having the large tools out and ready to go, ie, no pulling the planer out from under the bench and hooking up the DC piping; there is a router in the table ready to go, etc.
All this is fine but sometimes you just have to do whatever is necessary to accommodate a problem even if it isn't your first choice.
Space is the primary consideration. I use 1/3 of a three car garage partially "walled off" with plastic curtains to minimize dust in the rest of the garage.
At least that was my theory after 6 small shops with an ultimately frustrating fixed design. Of course if one has space to burn and don't mind walking around then a fixed design might be ok. My shop is 335 square feet and works for full flat work as well as turning. I have two lathes, 16" band saw, 8' heavy bench, sanding and router stations, and a Minmax combination machine. Also a central Oneida dust collector and big compressor (outside in a separate cabinet.)
- All my wall storage hangs on French cleats and can be moved around. They are standard at 32 wide by 36 high. Any space in between I use either for dust collector ducting or shelves on cleats that can be easily removed. It helps a lot that I have an attic space in the rafters for storing junk, and a shelf above the garage door.
- All my floor storage is the same height and dimensions. And on 2" wheels. They get moved around a lot. My wheels lock, but I rarely need to use that feature even for my Delta 460. I can group them together and clamp them to make a temporary large assembly table. The cabinets have full extension slides for drawers of different heights to hold chucks, tools, fixtures, rests, etc.
- One wall is 4x4 vertical posts to the ceiling, lag bolted at top and bottom to the wall studs. 5/8 holes at a 5 deg angle receive long and short 1/2 black pipe shelf supports. This is for wood, blank, and other storage, even less used tools at working height. I always keep extra pipe on hand for rearrangement as my needs change.
- I drew up my shop dimensions on a 1/4 grid on heavy paper. Each tool and cabinet and bench is on a little sticky template. As I get a new tool, or my habits change, or I am bugged by some limitation I play with the design. Usually I can do a major reorganization in a few hours. After may 6 such my shop has finally stabilized somewhat. But I know I will never be done.
My current shop was designed on paper to be a woodworking shop with room for a big table saw, a bench with two miter saws (10" and 12"), a grinder and Baldor buffer, band saw, planer, scroll saw, 6X48 belt sander, strip sander, jointer, router table/cabinet and workbench. I also planned for the Shopsmith I had which I continue to use as a horizontal boring machine, drill press, overhead router and drum sander.
Note that there is no mention of lathe. I was not turning when I built this shop and it was almost 15 years after building it that I began turning.
When I started turning it was on the Shopsmith and quickly learned that it was too short to turn at for any length of time. I went and bought a dedicated lathe and began the rearrangement of my shop to accommodate the lathe and turning tools.
I have had to move out the 6X48 sander, remove an assembly table, and rearrange my wood storage to accommodate my lathe. Fortunately the workbench and table saw are nearby to provide horizontal surfaces for piling wood blanks.
I still do some flat work but for how much longer I cannot say. I find the lathe so much more gratifying. Even a lengthy lathe project only takes a couple of days whereas most of my flatwork projects monopolize the shop for a week or more, sometimes much more.
Steve I'm a tool nut. I guess that is at least part of why I do all the hobbies I do. That's means I can never have enough space. In fact the space I have now is too big to afford to heat but too small for the tools I have.
I've thought several times that I would like to simplify like Clay Foster did. But everytime I think of doing that a project comes up where I need the tools I think I would get rid off. My son decided he wanted to build a new bookshelf so we have used the Tablesaw, Radial arm saw, router table and workbench. I'm doing some repair work on a Camera Ball head for work so I need the metal lathe.
For me it's just a never ending process of "if I had this tool I could do that" So when I win the lottery this weekend I'll build the ultimate shop that has little tiny living space somewhere. I remember reading an article once about guys who had bicycles more expensive than their cars. I'm headed that way when it comes to shops.
